OBD0 engine into OBD2 chassis HELP!!!
Old Feb 25, 2012 | 03:01 PM
MEn'MYEK's Avatar
Icon2 OBD0 engine into OBD2 chassis HELP!!!
Okay so I killed my D15b7 swap and now Im trying to swap in a big bad DOHC. I found myself a obd0 b18a1 swap (out of 90 integra) and the only parts I have for the swap so far:
New OBD2a engine harness
B series mounts (minus rear mount bracket)
what else will I need to swap this obd0 motor into my obd2 chassis? Axles? Mounts? Wiring? etc.
all help would be greatly appreciated!!!!
Old Feb 25, 2012 | 04:36 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: OBD0 engine into OBD2 chassis HELP!!!
What car and model is it?
Old Feb 25, 2012 | 05:42 PM
MEn'MYEK's Avatar
My car is a 98 civic EX.
donor car is a 90 integra GS.
Old Feb 25, 2012 | 05:50 PM
Tim1982's Avatar
Just use your wiring harness, you need a hydro transmission, swap mounts, linkage, a 98 integra ls ecu, use obd2 injectors, you need a t bracket off a 99-00 si, a obd2 altranator, integra axles, am I missing anything,
Old Feb 26, 2012 | 08:59 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Why not just do a swap that is legal?
Old Feb 26, 2012 | 10:03 AM
Arthas's Avatar
Youre going to put a 22 year old engine into a 1998??
#shithondapeopledo
Old Feb 26, 2012 | 11:25 AM
91ef_civic's Avatar
if u keep it OBD2 i believe you u will also need to swap the oil pump over for the crank sensor. the obd0 block will not have this.
Old Feb 26, 2012 | 12:22 PM
Technical Hero
Depends a lot on what ECU you will be running? Which one do you plan on doing?
Old May 25, 2012 | 08:27 AM
aflyingpanda's Avatar
i am currently doing the same. except i just changed the altenator and dizzy plugs to obd0 and then changed the injector with my single cam ones to run obd2a injectors.
but no crank :\
Old May 27, 2012 | 02:08 PM
Technical Hero
So you're using an OBD0 distributor with an OBD2 ECU?
Old Jun 1, 2012 | 11:47 PM
Yeah but it works. I got it running a few days ago but just need new mounts and tps sensor
Rob C
Sep 22, 2009 06:33 AM
catchmeifucan01
Apr 9, 2009 09:13 AM
boosted-delslow
Mar 10, 2004 06:36 AM
