Is this OBD0 2 OBD2b correct?
Old May 20, 2005 | 04:28 PM
khmoe's Avatar
Default Is this OBD0 2 OBD2b correct?
I'm getting a B18c (JDM) soon(5.jun). so i'm getting a conversion harness from jkob.com.
But i want to know if my conversen is right or not.
Pleas help me.
Tanx for any reply
Kristian Moe
Norway
A Plug:-------------------------------------------OBD2b
A1 (brn1)---------------------------B5 (yel)----Injector 4
A2 (blk1)----------------------------B10 (blk)---Power Ground 1
A3 (brn2) new cabel *------------B11(brn)-Injector 1
A4 (blk2)----------------------------B2(blk)------Power Ground 2
A5 (red1)----------------------------B3 (red)----Injector 2
A6 (red2)----------------------------A6 (red)----Evaporative Purge Valve
A7 (red3) new cabel *------------B4 (blu)---Injector 3
A11 (grn/wht)----------------------B23(blk/blu)--EACV(IACV)
A12 (grn/yel) ----------------------A15(grn/yel)----Fuel Pump Control 1
A13 (yel/blk) ----------------------B9 (yel/blk)-----ECU Power 1
A14 (grn/yel2) Unkown------------Unkown--------Fuel Pump Control 2
A15 (yel/blk2) -----------------------B1 (yel/blk)-----ECU Power 2
A16 (brn/blk)------------------------B20(brn/blk)-----Logic Ground 2
A18 (blk/red) ------------------------B22(brn/blk)------Logic Ground 1
B Plug:
B1 (wht/blu)---------------------------B21(wht/blu)---------ECU Memory
B2 (orn-----------------------------------C1-------(Tandem valv)O2 Heater Control
B6 (grn/orn) ----------------------------A18-----MIL (Check Engine Light)
B8 (blu/red) -------------------------------A27 -----A/C switch
B13 (blu/wht) ------------------------------A24--------Starter Signal
B14 (pink) ----------------------------------C5 -----Alternator
B15 (red/grn)------sam asB17-------------B13------Ignitor 1
B16 (yel/blu)--------------------------------C23-----VSS (Speed Sensor)
B17 (red/grn) ------same asB15-----------????-----Ignitor 2
B20 (brn)-------------------------------------A10----Service Check Connector
C Plug:
C1 (blu/grn)-----------------------------------C8-----CKP P
C2 (blu/yel) -----------------------------------C9----CKP M
C3 (orn/blu) ----------------------------------C20----TDC P
C4 (wht/blu) ----------------------------------C21----TDC M
C5 (red/yel) ----------------------------------C25(red/yel) ----IAT (Intake Air Temperature) Sensor
C6 (red/wht)----------------------------------C26(red/wht)---CTS (Coolant Temperature Sensor)
C7 (red/blu)-----------------------------------C27(red(blk)---TPS Output
C11 (wht) -------------------------------------C17----MAP Output
C12 (grn/wht) ---------------------------------C18-----Sensor Ground++++++
C13 (yel/wht) ----------------------------------C28(yel/blu)---TPS (Sensor Power)
C14 (grn/blu) -----------------------------------C7----MAP Ground
C15 (yel/red) -----------------------------------C17(wht/yel)---MAP Power
C16 (wht) ---------------------------------------C16---Oxygen Sensor Output
Added Wires (Pins are, of course, on 1992-1995 plugs):
-B12(grn/yel)-----------VTEC Solenoid
-C3(red/blu)----------knock sensor
-C10(blu/blk)---------VTEC Pressure Switch
-C29--------------------CYP P
-C30--------------------CYP M
-B11--------------------Injector 1
-B4--------------------Injector 3
-A26--------------------P/S Oil pressure
not sure i need:
-D2 (grn/wht)--- Brake Signal---------- A32 (grn/wht)
-B4 (???)--not used ---A20 ---------- Cooling Fans
-B5 (???)--not used --- C2----------- Alternator
-B19 (???)--no used -- A30------------ ELD (Electric Load Detector)
Old May 21, 2005 | 09:39 AM
khmoe's Avatar
Default Re: Is this OBD0 2 OBD2b correct? (khmoe)
TTT
Anyone know?
=-JDM-EG-=
Apr 9, 2007 02:36 PM
slorex
Aug 31, 2005 09:42 AM
blkb18
Jul 30, 2005 02:49 AM
90civic-racer
Apr 1, 2003 04:34 PM
