obd0-1 conversion wont start
Old Mar 26, 2003 | 05:29 AM
KevronsEG's Avatar
Default obd0-1 conversion wont start
its a d16z6 in a 91 crx si
checked teh injector wiring an dits good check teh dist. wiring and tryed doing teh white wire trick too. number 1 and 3 cly. spark plus are wet with gas and 2 and 4 cly spark plugs are bone dry. no spark i did teh screw driver trick. any ideas guys please help. also no codes too.
Old Mar 26, 2003 | 11:30 AM
KevronsEG's Avatar
Default Re: obd0-1 conversion wont start (CIV616)
anybody
Old Mar 26, 2003 | 12:23 PM
Jonathan_ED3's Avatar
what 'trick' are you talking about?
Old Mar 26, 2003 | 12:25 PM
KevronsEG's Avatar
Default Re: obd0-1 conversion wont start (hot_EG)
there are two white wires and thee is now ay of knowing witch oen goes were. so you can switch thema nd if it work sthen yoiu had them backwards
Old Mar 26, 2003 | 01:24 PM
Furry
Guest
Posts: n/a
what ecu and distributor are you using? are you using the obd0 stuff or obd1 stuff?
[Modified by Furry, 10:25 PM 3/26/2003]
Old Mar 26, 2003 | 04:12 PM
KevronsEG's Avatar
Default Re: obd0-1 conversion wont start (Furry)
obd 1 of course
Old Mar 27, 2003 | 10:39 AM
Furry
Guest
Posts: n/a
no codes and no spark....... check the coil and make sure the icm is hooked up properly
Old Mar 27, 2003 | 12:28 PM
Katman's Avatar
are you using an ecu jumper that you bought from somewhere or did you hack up your EF harness and apply the OBD1 female ecu plugs?
Old Mar 27, 2003 | 02:37 PM
red civic standard's Avatar
Default Re: obd0-1 conversion wont start (Katman)
he is using an ecu jumper that he bought, using the stock CRX SI wiring harness.
We had to splice on the OBD1 injectors clips (and remove the resistor box) and the OBD1 distributor plugs, but this was just a matter of matching colors.
He added wires for VTEC and such from the ecu jumper.
Old Mar 27, 2003 | 03:38 PM
Fobtions's Avatar
Default Re: obd0-1 conversion wont start (red civic standard)
not all ecu jumpers are plug and play it depends on what modifications are on the obd0 side ie: ELD is not there and i believe p28's look for that and the pr3 obd0 ecu's dont.
Old Mar 27, 2003 | 03:57 PM
Slurp56's Avatar
Default Re: obd0-1 conversion wont start (Fobtions)
ELD wire is there.
I remember that when doing my conversion, I had to switch a couple of the distributor wires. I matched the colors and no bueno. I had to switch 2 sensors locations. Sorry I cant be more specific, it was a long time ago.
Old Mar 28, 2003 | 05:41 AM
Default Re: obd0-1 conversion wont start (Slurp56)
problem is solved.
bad ignition coil led to no spark.
clogged fuel injectors led to wet plugs.
cwf1988
Jan 3, 2009 02:11 AM
FOMULA91
Aug 13, 2008 05:17 AM
Cimburke23
33
Sep 1, 2006 05:59 PM
KevronsEG
Mar 28, 2003 05:43 AM
KevronsEG
11
Mar 28, 2003 05:42 AM
