OBD conversion questions
Old Jul 24, 2004 | 05:03 AM
slambedcivic's Avatar
Default OBD conversion questions
i searched and found nothing...
heres the story, i was supposed to get a 94/95 obd1 B18B engine swap. unfortunately they sent a 96 B18B which is OBD2. what i need to know is: will it be okay just to run the OBD2 ECU, with a OBD1 to OBD2A jumper harness? and be done with it at that point.
Modified by slambedcivic at 11:25 PM 7/24/2004
Old Jul 24, 2004 | 02:16 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: OBD conversion questions (slambedcivic)
use your obd1 harness, injectors, and distributor or you can re-pin the distributor and change the clips on the injectors
Old Jul 24, 2004 | 02:22 PM
Default Re: OBD conversion questions (HOOKUPS)
PM sent
mat r 1
Sep 19, 2012 09:29 AM
beginmyhonda
Jan 11, 2010 05:02 PM
stevil_knevil
Nov 10, 2006 07:06 PM
integGSR805
Jun 19, 2005 01:28 AM
Quick 200k Mile Motor
13
Jul 25, 2002 09:11 AM
