OBD 1 to OBD 2
major problem. 1st the connection will not fit into the ECU (you need a jumper)
then if you're lucky, you won't get a CHECK ENGINE LIGHT (classic problem with OBDII is the error throwing..it happens often)
other than that nothing else...I think.
Civic VTi
Mar 15, 2002 07:21 AM
