OBD-1/0 Problems
Old Mar 10, 2003 | 11:31 AM
darkracer's Avatar
Default OBD-1/0 Problems
Just bought a d16z6 w/ brain. want to run the OBD-1 ecu and a jumper. I've been told i have to run the main OBD-1 plugs on the passenger and driver side, but the plugs match up pretty much the same except for a few wires left over. Has anyone done this swap because i need your help. Any help is greatly appreciated, need to get my new motor in and running. THanks. peace.
BTW to all hybiding guru's please.
Old Mar 10, 2003 | 06:54 PM
smokey2.0's Avatar
Default Re: OBD-1/0 Problems (darkracer)
just get jason's harness blown91hatch, i can't remember it exactly. once you get this, you'll need a obd1 distributor, a 4 wire O2 sensor, and of course a obd1 ecu!
Old Mar 10, 2003 | 08:19 PM
poison's Avatar
You're converting from OBD0 to OBD1 correct? Just wanting to clarify.
What I would do in this regard is get a Haynes/Helms manual (if you don't already have one) for your original car. Then also get the same manual for a 92-95 Civic.
That will display every single Pin-Out, I would compare and change wires for making it run properly.
Or you can build your own conversion harness, but that would definitely take some time.
Or locate an OBD0-OBD1 Conversion harness from someone and save yourself trouble
Old Mar 10, 2003 | 11:29 PM
Colin's Avatar
if you use a jumper harness like jason's there are 2 options for the injectors:
1) Use the stock obd0 injectors. don't change a thing, they will work just fine.
2) Use obd1 injectors. To do this you'll need to get some obd1 injector clips, cut the obd0 clips off of your harness and solder the obd1 clips on in their place. Next remove the resistor box. There will be 5 or so wires that lead into the resistor box from the injectors, cut these wires, then splice them all together, solder them and tape them up. Done. If you have access to an obd1 engine harness you can pull the corresponding plug off of it, this plug effectively connects all these wires, and that way you won't have to have an ugly looking bundle of wires that you soldered together.
10psiLsEf2
Nov 11, 2011 07:36 PM
xsi90teg
Jan 29, 2009 07:32 PM
jdmboi3278
Engine Management and Tuning
Jan 28, 2009 11:17 PM
MniMeHatch89
May 24, 2007 09:10 PM
skud_dusty
13
Apr 25, 2003 11:51 PM
