ob0 to obd1 dizzy wireing
Old Jan 7, 2007 | 11:02 AM
95_red_dc's Avatar
Default ob0 to obd1 dizzy wireing
I have a 91 crx si with b18b obd1 conversion. I need a little help on my dizzy wireing for my obd0 to obd1 conversion my intructions say to color match all the wires except the 2 white wires. One of the white wires go to the yellow and green wire which is suppose to go to the thicker white wire, and then the other white wire just goes to the other white wire which is suppose to be thinner. This is very hard to tell the differance in the size of the wires they look like the same size. If any one can please take a look at there wireing and help me out that would be awsome. I tryed both the wires and hook them up to see what happends and it runs with no cels, then I switched the white wires and the same thing run with no cels. I am useing my stock harness and if you peel the wires loom back one white wire goes with the other dizzy wires and the other white wire goes by it self in to the harness which one is the thicker white wire?
Old Jan 7, 2007 | 02:31 PM
95_red_dc's Avatar
Default Re: ob0 to obd1 dizzy wireing (ls_swaped_crx)
bump
Old Jan 7, 2007 | 06:13 PM
_unclejuice's Avatar
the sheathing may be the same thickness, but did you check the diameter of the actual strands of wire inside?
Old Jan 8, 2007 | 03:30 AM
Ovrbst_T66's Avatar
One of the two white wires should have a red marking on it.That one will go to the grn/yel wire.
Old Jan 8, 2007 | 03:27 PM
95_red_dc's Avatar
Default Re: ob0 to obd1 dizzy wireing (danny_t66)
So there is a white wire that has a red mark on it that is the one that connects to yellow and green wire thanks I will go out and check here shortly
Old Jan 9, 2007 | 11:31 AM
95_red_dc's Avatar
I looked for the red markeings on any of the white wires and I could not find them.
Old Jan 10, 2007 | 07:29 AM
goforbroke's Avatar
MEAT PATTY
You have to search my friend...........
Theirs enough information on this site to take apart your car and put it back together again.
https://honda-tech.com/zero...age=1
https://honda-tech.com/zerothread?id=1641425
Old Jan 10, 2007 | 08:18 AM
95_red_dc's Avatar
Default Re: ob0 to obd1 dizzy wireing (goforbroke)
THanks that thats all I needed, but I did search I guss not hard enough
Old Jan 10, 2007 | 08:22 AM
goforbroke's Avatar
MEAT PATTY
Its cool have fun converting.
Dancing is Forbidden
Dec 1, 2005 09:14 AM
rasta420
Jun 21, 2005 07:41 PM
Jurassic Four
Sep 20, 2004 03:19 AM
BoRiCuA
18
Jun 21, 2004 12:15 PM
turbotime.
Jun 7, 2003 11:09 AM
