o2 sensor problems?
Old May 17, 2002 | 02:41 PM
11secdx's Avatar
Default o2 sensor problems?
its a 92 hatch. b20z with Ls computer, manifold, injectors,obd1. its been throwing the o2 code(1).i installed a new bosch universal sensor. ran fine for three days. then it threw the code again.need suggestions.
Old May 17, 2002 | 03:01 PM
dumbmadtech's Avatar
Default Re: o2 sensor problems? (11secdx)
First check your wiring. Usually aftermarket o2 have 2white 1black 1 grey. The 2 blackwires on your car go to the 2 whitewires on o2 the green on your car to grey on o2 and the white on your car to black on o2 sensor. If not the antiseize will destroy the sensor and if your car is to low and you hit your hedder on something that will take out the heater circuit pretty easy.
Old May 18, 2002 | 06:47 AM
11secdx's Avatar
Default Re: o2 sensor problems? (dumbmadtech)
its located in the cat. are you saying the antiseize will destroy a sensor?
Old May 18, 2002 | 09:25 AM
Only if it drips down too much past the threads. If you put too much it can happen. So dont smear the antiseize around too much. That why they give you the plastic ring already with anti seize. Be careful.
Old May 18, 2002 | 02:06 PM
11secdx's Avatar
i rewired my mistakes, from the info you posted. and rewired the ground on the A/F gauge for safe measures. you wouldn't happen to know where the stock location for the obd1 LS is located? thanks again
Civic98KH
15
Dec 10, 2012 08:26 PM
4tika4
Jul 25, 2009 05:23 AM
Integra_Boi
Oct 1, 2004 08:07 AM
boost fed ls
Aug 31, 2004 07:45 PM
