Need some tips on engine removal/install
Old Sep 1, 2003 | 08:36 AM
Stewie's Avatar
Default Need some tips on engine removal/install
I want to take the engine out of my teg from underneath the car. Is it possible to remove and engine and line it up for instillation with a floor jack?
Any help is appreciated.
Old Sep 1, 2003 | 09:48 AM
MaxSterling's Avatar
Default Re: Need some tips on engine removal/install (Mac8008)
yes, its ez, just be carefully, when you jack the car up that high.
you can use a pallet w/ wheels to position the engine
Old Sep 1, 2003 | 10:01 AM
Stewie's Avatar
Default Re: Need some tips on engine removal/install (RoyFokker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">yes, its ez, just be carefully, when you jack the car up that high.
you can use a pallet w/ wheels to position the engine</TD></TR></TABLE>
Thanks for the reply.
I didn't want to drop the engine on a pallet though because I won't be able to get my car low enough.
That's why I want to use a floor jack to place under the engine and pull it out while the front end is off the ground. Do you think this would be hard to do?
Old Sep 1, 2003 | 01:42 PM
if you can balance your heavy *** engine and tranny on a single or two jacks, then you should join the circuss full time...it im possible in my mind. if you use a pallet you can lower car frame enough to drop on pallet. this is my recommendation. its your project so you can attempt it any way you want, but i cant see using jacks under engine a smart thing to do.
Old Sep 1, 2003 | 01:53 PM
Stewie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RoyFokker &raquo;</TD></TR><TR><TD CLASS="quote">if you can balance your heavy *** engine and tranny on a single or two jacks, then you should join the circuss full time...it im possible in my mind. if you use a pallet you can lower car frame enough to drop on pallet. this is my recommendation. its your project so you can attempt it any way you want, but i cant see using jacks under engine a smart thing to do.</TD></TR></TABLE>
I guess a hoist it is.
Old Sep 1, 2003 | 06:48 PM
VTECVillain's Avatar
If you install the engine and tranny separately it's not that hard to do without a hoist as long as you have another person helping out. I've done 4 swaps from underneath without using a hoist and had no problems at all. Actually it's faster than with a hoist putting it in from the top in my opinion.
We do the motor first lining up the driver's side mount. Then the tranny, and so on... I just installed a second gen B16A into a 94 Del Sol the day before yesterday using the "human hoist" method. If you have a little muscle then put it to some use
Old Sep 2, 2003 | 07:43 AM
Stewie's Avatar
Default Re: Need some tips on engine removal/install (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">If you install the engine and tranny separately it's not that hard to do without a hoist as long as you have another person helping out. I've done 4 swaps from underneath without using a hoist and had no problems at all. Actually it's faster than with a hoist putting it in from the top in my opinion.
We do the motor first lining up the driver's side mount. Then the tranny, and so on... I just installed a second gen B16A into a 94 Del Sol the day before yesterday using the "human hoist" method. If you have a little muscle then put it to some use </TD></TR></TABLE>
Sounds good. What did you use to line up the engine with the mounts? A dolly?
I AM WEASEL
Oct 8, 2008 06:40 PM
92shade
Aug 16, 2008 11:13 AM
NatedoggAZ
Aug 13, 2007 08:23 PM
meagainsttheworld
Aug 18, 2006 09:11 PM
SamC
Aug 20, 2002 12:08 PM
