Need some serious help
Old Jun 28, 2003 | 09:13 PM
Raff's Avatar
Default Need some serious help
OK.. in my 94 civic ex is a b16a2 99-00 si ... wiring harness is mangled.. a 12v wire is running from my cabin fusebox to my dizzy and my VSS giveing them power... well.. now only to the dizzy and the VSS no longer works ... i'm replaceing my stock wiring harness with a new one due to the fact this one is mangled.. as i mentioned ... what harness should i use... i need one that will plug in at my shock towers ... some help plz .. i'm a noob in trouble
Old Jun 28, 2003 | 09:23 PM
Kamin's Avatar
Default Re: Need some serious help (Raff)
why the **** did you post this twice??
just get a 94 civic EX harness or fix the one you have. its not that hard to buy 2$ worth of split loom and make everything look pretty again.
Old Jun 29, 2003 | 10:04 AM
JDM CRX's Avatar
Default Re: Need some serious help (Kamin)
Use your stock wiring harness, youll need an OBD1 dizzy and injectors. Get your stock ECU rechipped through Kenji. Run your VTEC solenoid, oil pressure, and knock sensor to the ECU. Connect the ground on the oil pressure sensor straight to the engine and your done. Search for my user name and type in KEnji, youll find his email in one of my threads. Ive have 2 Ecu's done through him and no complaints, good guy!
Jul 10, 2006 08:51 PM
nelsond
Feb 26, 2006 04:01 PM
b16pwrcrx
Feb 7, 2004 12:12 PM
Raff
Jun 30, 2003 10:19 AM
jcivic
Mar 1, 2003 06:16 PM
