need oxygen help!
Old Apr 4, 2003 | 04:23 PM
Richibahn's Avatar
Default need oxygen help!
I am currently running a 1995 B18c1 jap spec in my 92 ex coupe, and i have no plug for the O2 sensor. I need to come up with a harness or somehow fix this to eliminate my problem...v-tec is not hitting right, and i was told that my ecu is running in default tune mode. so i'm not too happy, and nervous that i'll blow my **** up soon. please help. thanks.
Old Apr 4, 2003 | 06:06 PM
Blaze45's Avatar
Brrraaaap!
Default Re: need oxygen help! (Richibahn)
http://www.jdmhondaparts.com has a bung that you can have a shop weld in and then run a o2 to it.
Blaze
Old Apr 4, 2003 | 06:41 PM
Richibahn's Avatar
Default Re: need oxygen help! (Blaze45)
sorry, I may not be that clear with my problem. i have the bung, i have no plug on the harness to run the O2 sensor. i need the plug, I was told since I had the motor shipped from japan, it has a different harness, with no emissions control or something. maybe i'm wrong, but i know I have no oxygen sensor hooked up to my harness.
Old Apr 4, 2003 | 07:09 PM
VTECVillain's Avatar
That's not true because JDM motors utilize O2 sensors. Did you do your own swap or did a shop do it for you? I doubt that the JDM harness was used, but even if it was there should be a plugin for the O2 sensor unless it was hacked. If you can't find one, you could always wire it directly to the ECU pinouts using your own wire.
Old Apr 4, 2003 | 07:25 PM
Richibahn's Avatar
Default Re: need oxygen help! (VTECVillain)
yes i did my own swap, and it runs pretty good, but i'll look again. I tried all of the plugs that I have left over and none of them fit the open ones off the harness that I have. I bought the motor off of an older guy who put this motor in his crx before I had it. I have the crx harness he used too, but it was no use to me so i sold it to my friend. i'll look again, but about hard wireing it to the ecu, how would I go about doing that? i'm pretty new to this stuff, never been this deep into a car, so i'm learning as i go.
stiffinEK
Mar 8, 2009 09:43 PM
JDM Roc
Aug 13, 2008 05:19 AM
HatchSpeeD
May 23, 2008 05:17 PM
mr. goodwrench
Jun 11, 2005 07:07 AM
