Need help, knock sensor CEL randomly, engine running odd.
Old Feb 6, 2006 | 05:43 PM
lshatch92's Avatar
Default Need help, knock sensor CEL randomly, engine running odd.
I have a B16A3 I/H/E that has been running fine for quite a while now... I recently put a skunk2 manifold on it with a maxbore throttlebody 68mm... anyways I ran the car orignally for a few miles and the car was running a little rough but i figured to warm it up since it hadn't been ran in weeks, randomly I get a CEL for "knock sensor" so... I put the stock T/B on it for ***** and giggles to see if anything was different, reset the ecu and now I get knock sensor CEL every startup... So im at a dead end as of not knowing if the knock sensor is detecting a knock or if I need to replace the knock sensor? I'm hoping someone has had a similar problem or something and can help me out...
come on technicians ;p
Old Feb 7, 2006 | 08:16 PM
CP9A6M's Avatar
Default Re: Need help, knock sensor CEL randomly, engine running odd. (lshatch92)
I am having the same problem with my b16a skunk2 cams and manifold also, but stock throttle body, i'm also getting a code 23 every time i run the engine, no clue what the deal is.
Old Feb 8, 2006 | 08:05 AM
lshatch92's Avatar
ya code 23 knock sensor
Old Feb 9, 2006 | 09:59 AM
lshatch92's Avatar
CP9A6M: how does your car run? does it run alright or like rough? get back to me
Old Feb 11, 2006 | 11:30 AM
CP9A6M's Avatar
Default Re: (lshatch92)
It runs fine, lots of vibration, but I assume that's just because of the hasport mounts.
Old Feb 19, 2006 | 10:51 PM
CP9A6M's Avatar
Default Re: (CP9A6M)
Now I replaced the knock sensor. Night and day difference, SO much more power now, and the added bonus of no CEL.
Modified by CP9A6M at 5:48 PM 3/3/2006
ELSUICIDA
Apr 15, 2007 05:13 PM
VTECth1s
Aug 20, 2006 02:16 PM
lshatch92
Feb 13, 2006 06:34 AM
jtracing919
Feb 7, 2005 11:41 AM
xXx Justin xXx
Jun 11, 2004 02:01 AM
