knock sensor
Old Feb 6, 2005 | 09:39 AM
jtracing919's Avatar
Default knock sensor
95 rs b18c swap. i am having intermittent cel for knock sensor. it will throw the cel and then it will be fine for days?
Old Feb 6, 2005 | 10:58 AM
Quiks66's Avatar
Default Re: knock sensor (jtracing919)
Are you using a knock sensor? It sounds like you're using one but either it is detecting a vibration (and reading it as a knock) or the wiring itself was not done well. Need more info
Old Feb 7, 2005 | 11:41 AM
Default Re: knock sensor (Quiks66)
i am running a knock sensor. it threw the cel 3 times. I reset my ecu and adjusted my valve clearences. it hasn't done it since? I run premiun and the car doesn't rattle like its predetonating.
j me4door
Apr 7, 2009 06:37 PM
RoB316
Apr 20, 2007 03:39 AM
ELSUICIDA
Apr 15, 2007 05:13 PM
