need help with h22a please!!!!!
Old Feb 3, 2003 | 04:20 PM
mxpx035's Avatar
Default need help with h22a please!!!!!
my car was running fine today and i decided to do a compression test it had 215 all the way across but when i put the plugs back in to start it there is no spark now i have new plugs cap and rotor what could it be i checked all the fuses and the grounds everything is good but there is just no spark how can i test to see if the crank shaft positioning sensor is bad? or what should i look for
[Modified by mxpx035, 8:36 PM 2/3/2003]
Old Feb 3, 2003 | 05:01 PM
LshatchTurbo's Avatar
New User
Default Re: need help with h22a please!!!!! (mxpx035)
So you are positive you connected the engine ground strap? The wire on the coming from the engine to the chassis. I dont see how just pulling your plugs out would cause your car to stop running.
Old Feb 3, 2003 | 05:57 PM
google's Avatar
Default Re: need help with h22a please!!!!! (lshatchturbo)
ur gettin no spark... how did u do ur compression test... did u hand turn ur crank... whatever check ur coil... and while ur at it make sure ur really not getting spark ... hold the spark plug wire to ur valve cover and see if u see any spark when ur cranking... does it even crank...
[Modified by 1320in11, 2:59 AM 2/4/2003]
Old Feb 3, 2003 | 06:20 PM
mxpx035's Avatar
Default Re: need help with h22a please!!!!! (1320in11)
i turned it over by the key and i already held it up to the valve cover and no spark i even went out and bought a new cap and rotor and i cleaned all my gorunds and checked my fuses and still no spark i don't under stand it ran fine before the compression test and how do i check the coil and the crank position sensors?
Old Feb 3, 2003 | 08:26 PM
Qfactor's Avatar
You probably shorted your igniter, if you did not unplug the two pin plug from the distributor blk/yel & blu wires. next time use a remote starter or unplug the power supply to the distributor and fuel pump. or just unplug the ecu.
Old Feb 5, 2003 | 09:44 AM
Jason kiDD's Avatar
Default Re: need help with h22a please!!!!! (Qfactor)
Yeah my guess is the ignitor as well. Make sure that the 4 connections are secure and if they are then take it out and have it tested or replaced..
Old Feb 5, 2003 | 10:57 AM
AccordDriver92's Avatar
damn...hmmmm
KStuned's Avatar
Default Re: need help with h22a please!!!!! (Jason kiDD)
I did a tranny in a 96 gsr last month, got done,... wont start. Check for spark... NONE, replaced the ignitor.... started right up. Bad news is that a new ignitor is $180 from Honda!
Old Feb 10, 2003 | 01:15 PM
mxpx035's Avatar
Default Re: need help with h22a please!!!!! (Hondaddict)
i found out it was my coil and also found out b and h series have the same coil my friend had a b16 dist. and the coils had the same part # so i switched them and it started right up
Old Feb 10, 2003 | 01:34 PM
k_spek's Avatar
Any other h22 guys compression tested their motors? What were everyones results?
Is the compression tester at sears pretty accurate? You are supposed to only crank it 5 times right?
Mxpx do you have a jdm h22a? That's good you fixed the problem and your cars running again.
Old Feb 11, 2003 | 05:29 AM
EK22Tim's Avatar
Default Re: need help with h22a please!!!!! (laugHin22CX)
I did mine, but I thikn I cranked it too many times! I jsut kept cranking till the needle stopped jumping. The results were 260-262-260-265. Like I said, that was crank till the needle stopped.. so Prolly did it wrong, but dang those are some high numbers!
Old Feb 11, 2003 | 09:08 AM
Civic Rs's Avatar
New User
Default Re: need help with h22a please!!!!! (EK22Tim)
H22a JDM 4-5 crank
235
230
235
230
Old Feb 11, 2003 | 01:17 PM
k_spek's Avatar
Default Re: need help with h22a please!!!!! (Civic Rs)
Mine results were about 265 across the board with 4-5 cranks. This was with the engine warm and the throttle fully open.
If i cranked the engine about 7-8 times the numbers went up to 275-280, but i know it says on c-speed to crank it only 4-5 times.
This was done with a compression tester bought at sears. I don't know how accurate it is. I just wanted to see other peoples compression test results to compare.
O BTW it is a 94 jdm h22a.
Old Feb 16, 2003 | 05:55 PM
mxpx035's Avatar
when i compression tested my car i don't think i turned it over enough and it was cold i am going to do it again with it warm and see what happens and yes i have the jdm h22a
Old Feb 16, 2003 | 11:03 PM
JDMH22HATCH's Avatar
Well I just did a compression test on mine about an hour ago. 95 JDM H22a
210
213
215
220
But I've been having issues with my motor so I'm going to double check tomorrow.
Old Feb 17, 2003 | 12:37 PM
Default Re: need help with h22a please!!!!! (JDMH22HATCH)
Well, I did another compression test and now my car won't start. I'm Jinxed I swear. I read this post and look what happened. J/K. Well the car seems like its going to turn over but it doesn't. I haven't checked for spark yet because Im doing a clutch i an eclipse right now. Just curious on what else it could be besides the ignitor if anything. I didn't unplug the PGMFI, so I originally thought it was just flooded, but it sat for quite a few hours now and still won't start. I've got a full GSR motor in my garage, so I could use the ignitor for now, but I was just wondering what else it could be. Thanks guys in advance for the help.
Old Feb 18, 2003 | 05:46 PM
mxpx035's Avatar
thats what happened to me and it was my coil and the b series one is the same you can just switch it out
LSteggyguy
19
Dec 2, 2018 12:18 AM
raczyk
Dec 19, 2005 04:01 PM
NCPreludeDriver
Feb 7, 2005 08:57 PM
KaRiZMa
Nov 1, 2004 04:19 AM
smallttocs
May 25, 2004 08:39 PM
