need help with engine code
Old Dec 28, 2001 | 07:54 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default need help with engine code
i have a customer that has a 97 accord with a 98 prelude engine.it had a civic ex ecu in it and threw several codes and did not run good.i got him a 96 prelude ecu and it works but throws code 20-electronic load detector.i am going to have to work on it next week and was wondering if anyone has come across this problem before so i would know what to try.also the ecu is an auto ecu and of course it throws a code for that too.is there a way to trick the ecu so it doesn't throw this code or do i need to send the ecu back and get a manual one?
Old Dec 28, 2001 | 11:48 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: need help with engine code (turbotypeR)
Code 20 - ELD.
Check all grounds and make sure they are making GOOD contact.
MelloYelloCRX
Jul 22, 2006 05:17 PM
brega3
Jun 30, 2003 03:43 PM
