Need Help... code 23
Old Apr 20, 2003 | 06:52 PM
GsTeg90's Avatar
Default Need Help... code 23
recently put a b18c1 in my 90teg. using pr3 ecu
getting code 23... i know thats knock sensor.
i have v-afc hooked up and somewhat vtec is engaging but does'nt feel the way its suppost to"weak". Is the knock sensor causing this weak VTEC.
all help is greatly appreciated.
GsTeg90
Old Apr 20, 2003 | 07:44 PM
GsTeg90's Avatar
Default Re: Need Help... code 23 (GsTeg90)
TTT
GsTeg90
Old Apr 21, 2003 | 04:54 AM
GsTeg90's Avatar
Anyone?
GsTeg90
Old Apr 21, 2003 | 09:31 AM
GsTeg90's Avatar
ttt
Old Apr 21, 2003 | 09:38 AM
Finest's Avatar
There is no such thing as a "weak" VTEC crossover. Either it works, or it doesn't. You CAN tell the difference, especially with a B18c1. What you're "hearing" is probably the IAB (secondary intake runners) opening up...and not the bigger VTEC lobes itself.
Get a new knock sensor and diagnose it from there.
Old Apr 21, 2003 | 09:51 AM
GsTeg90's Avatar
well i feel some sort of a pull after 5000rpm.
i have skunk2 IM. is it possible that its just the VAFC thats sending the vtec signal but the ECU is not activating it because of the knock sensor.
GsTeg90
Old Apr 21, 2003 | 10:49 AM
Katman's Avatar
Default Re: (GsTeg90)
you should set vtec to kick on around 5500-5700rpm.
The 'weakness' or lag in power you speak of is more than likely the dip in the powerband once vtec kicks on, if you have it kickin on too early (under 5500rpm). Try upping the vtec x--over point and it should clear that lag up, somewhat. And yes, if you're running a stock DOHC VTEC ecu w/the KS unplugged/not wired up will in a sense, kill power, moreover, makes your engine feel like it hesitates. Either wire up the KS or have the ecu reprogrammed w/a disabled KS program. I suggest you just wire it up though, if you're engine is mostly stock.
Old Apr 21, 2003 | 11:42 AM
GsTeg90's Avatar
engine has pr3 pistons,Skunk2 IM, p&p, ITR camshafts. AEM Cam gears, DC 4-1 headers.
So you think the Knock sensor is leading to power loss?
GsTeg90
Old Apr 21, 2003 | 12:06 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsTeg90 &raquo;</TD></TR><TR><TD CLASS="quote">engine has pr3 pistons,Skunk2 IM, p&p, ITR camshafts. AEM Cam gears, DC 4-1 headers.
GsTeg90</TD></TR></TABLE>
if your DOHC VTEC ecu is totally stock.....yes...the KS is prolly hampering performance some. I suggest you you have your ecu reprogrammed with those engine upgrades you've done, especially the SK2 manifold & ITR cams...
Old Apr 21, 2003 | 12:23 PM
GsTeg90's Avatar
so even with a v-afc , i still have to chip my ecu?
Old Apr 21, 2003 | 12:27 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsTeg90 &raquo;</TD></TR><TR><TD CLASS="quote">so even with a v-afc , i still have to chip my ecu?</TD></TR></TABLE>
the VAFC doesn't disable sensors.....but you can enhance fuel and the vtec crossover point with your VAFC.
Old Apr 21, 2003 | 12:31 PM
GsTeg90's Avatar
but if i wire my KS. will evrything be ok without having to chip my ecu?
and you think i should raise the vtec crossover to 5500rpm?
Old Apr 21, 2003 | 12:39 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsTeg90 &raquo;</TD></TR><TR><TD CLASS="quote">but if i wire my KS. will evrything be ok without having to chip my ecu?
yep, it should clear up the 'hesitation' feel. and yes to moving up yoour VTEC point...
I'm feelin dejavu...
Old Apr 21, 2003 | 12:45 PM
GsTeg90's Avatar
Alright man, i'm gonna take ure advice and do it. at 5500rpm.
And will wire the knocksensor today and will update .
You've been great help.
Thank You
GsTeg90
Old Apr 21, 2003 | 01:15 PM
Katman's Avatar
cool deal..hope it all works out.
dryhopsux13
Apr 8, 2005 06:02 AM
Brick Top
15
Oct 28, 2004 10:48 PM
Raunch
Nov 8, 2003 10:05 PM
89sir-9
12
Jan 23, 2002 10:40 AM
