need help ASAP
Old May 21, 2003 | 06:01 PM
bOOsTiNSoHcVtEc's Avatar
Default need help ASAP
swapped a b18b into my 95 civic ex and also converted it from auto to manual...everything is plugged up and it jus wont crank over...it doesnt even try to start...someone please help...i need some ideas by tomorrow...thanks
Old May 21, 2003 | 06:07 PM
VTECVillain's Avatar
Default Re: need help ASAP (bOOsTiNSoHcVtEc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">converted it from auto to manual...everything is plugged up and it jus wont crank over...it doesnt even try to start...someone please help...i need some ideas by tomorrow...thanks</TD></TR></TABLE>
Did you rewire the interlock from the auto shifter? If you don't wire the car directly into P or N then it will not start unless you leave the bottom part of the selector plugged in and it still needs to be in P or N. Even though your car has a manual tranny now, the wiring going to the ignition switch is auto so if the car thinks it's in "gear" it will not start.
Old May 21, 2003 | 06:29 PM
Default Re: need help ASAP (VTECVillain)
i hooked the 2 fat wires together and i dont know if i hooked the green with white stripe to another green one or the green with white stripe with the black wire...i forgot...is there anythin else i have to do?
Old May 21, 2003 | 06:53 PM
do i have to do anything with that blue box by ther clutch pedal...i jus took out the plug and left it disconnected
Old May 21, 2003 | 07:55 PM
95hbMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bOOsTiNSoHcVtEc &raquo;</TD></TR><TR><TD CLASS="quote">do i have to do anything with that blue box by ther clutch pedal...i jus took out the plug and left it disconnected</TD></TR></TABLE>
nope, I left mine unplugged and it's working fine....
Old May 21, 2003 | 08:00 PM
91civicEX's Avatar
try to push start it.
Old May 21, 2003 | 08:28 PM
Default Re: (91civicLX)
would that werk?
90blkteg
Jun 21, 2013 11:44 AM
98exturd
Jul 13, 2007 02:04 PM
Racewerkz
Oct 16, 2005 07:51 PM
bOOsTiNSoHcVtEc
May 21, 2003 08:27 PM
JDMvtecDRAGSTA
Mar 24, 2002 10:47 PM
