mounts and axles question....
I'm having way too many problems with my Ls motor. So i picked a b16a3 from a delsol. Now it has mounts on it. Can i use those mounts? My car is a 94 civic ex coupe. Also will i be able to use my civic axles or will i need new ones? Any support would be much appreciated. Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM*EG*Ls »</TD></TR><TR><TD CLASS="quote">I'm having way too many problems with my Ls motor. So i picked a b16a3 from a delsol. Now it has mounts on it. Can i use those mounts? My car is a 94 civic ex coupe. Also will i be able to use my civic axles or will i need new ones? Any support would be much appreciated. Thanks.</TD></TR></TABLE>
Both swaps require the same parts(aside from the Vtec wiring for B16 and ECU), both swaps would use same mounts and same axles.
What are the problems with the B18B?
Yes you can use the b16 mounts.
You cannot use your stock sohc axles, but if you have axles for your LS swap, those can be used.
You basically just need '94+ B series axles and intermediate shaft.
B16A3Civic*Eg
May 22, 2006 10:23 PM
x916
Northern California (Sales)
Jan 1, 2006 01:05 AM
All_Motor_Rex
Feb 3, 2004 02:17 PM
