Motor Swap or Not?
Old Feb 24, 2003 | 12:15 PM
Daiken's Avatar
Default Motor Swap or Not?
I'm going to get a 90-93 integra, what should i do cause i dont know cause i want to run all-motor with the B18A/B but it probaly wont produce as much power will it??If not that I was gonna do B20/Ls Vtec conversion or B18C1, but i dont know what should i get..i want something that would produce alot of power doing all-motor.
Old Feb 24, 2003 | 11:26 PM
Redline130's Avatar
Default Re: Motor Swap or Not? (Daiken)
I vote for a B18C1 or C5. Honestly though, it all depends on your budget and how much you really want to put into the car. But for all-motor, those would be my choices.
Old Feb 25, 2003 | 08:05 AM
Daiken's Avatar
Default Re: Motor Swap or Not? (Redline130)
okay if i choose B18C1, will it drop striaght in the 90-93 integra's with no customizing anything?
[Modified by Daiken, 5:05 PM 2/25/2003]
Old Feb 25, 2003 | 09:44 AM
Redline130's Avatar
You will have to use a cable type transmission, and decide what ecu you are going to use. If you go with the GSR ecu, then you will need to change the wiring to run that ecu or get a nonOBD to OBD1 conversion harness. Other than that, you should be good.
Old Mar 6, 2003 | 01:09 PM
Daiken's Avatar
so, i'll jus need hasport or place racing motor mounts so the engine(b18c1) would fit in the engine bay???
daiken performance
Old Mar 6, 2003 | 01:52 PM
irev210's Avatar
you dont even need a mount kit, id recommend a stock replacement kit though because your mounts will be old and soft.
I would recommend getting a 92-93 integra LS or GS, fromt here buy a 92-93 integra XSi swap, comes with the dope YS1 tranny and the obd1 PR3 ecu. Then I would save your block, hone it and slap some new pr3 pistons in on your LS rods, and rebuild the bottom end. Then when you have enough money, go the LS/VTEC route when you get tired of the slow b16
u will be very happy.
Just make sure to get stuff like ARP head studs, FPR and FPG... make sure your fuel mixture is not too lean
otherwise detonate and say goodbye to ur rings.
Old Mar 6, 2003 | 03:04 PM
poison's Avatar
Default Re: Motor Swap or Not? (irev210)
damn, you pretty much just planned out his whole car.
congrats.
josh564738291
Sep 17, 2008 10:38 AM
Twilight
Jan 9, 2006 06:42 AM
LittleWacker
12
Dec 23, 2005 09:29 AM
slammedteg
May 1, 2004 09:12 AM
Daiken
Feb 23, 2003 05:24 PM
