more problems..... (code 3) on h22a hybrid.
Old Aug 7, 2003 | 05:53 PM
HotWheelz's Avatar
Default more problems..... (code 3) on h22a hybrid.
tried 3 map sensors.. two are staying at 5 volts one at 2.25volts.. put of of them back in the other civic works great... on my h22a civic gives out a map code 3.
is there something about h22a that it only works with one certain map sensor ????
obd1 p28 ecu...
got the car idling fine now at 1200rpm with a fully built motor... running super rich!!!
can't drive it...
o2 heater sensor circuit code on new o2, could be all teh carbon ahhahaahahah.. i have another o2 sensor but i'm curious on the map sensor issue...
anybody have any input on this ?
Old Aug 7, 2003 | 07:13 PM
poison's Avatar
Default Re: more problems..... (code 3) on h22a hybrid. (HotWheelz)
Nope, there is no particular MAP sensor that needs to be with it. I am using my civic MAP sensor and works great.
It's probably the wiring that is messed up.
Grab a multi meter and make sure the wires complete to the ECU:
WHT to D17
GRN/BLU to D21
YEL/GRN to D19
Make sure vacuum is good to it as well.
Old Aug 9, 2003 | 06:39 AM
HotWheelz's Avatar
Default Re: more problems..... (poison)
my super talents mixed two wires when building my harness .. works now
runderwo
Sep 26, 2011 07:29 AM
hatchbkdrvr
Jan 3, 2008 05:39 AM
deftones0817
Sep 20, 2005 05:58 AM
H22A EG6
Feb 29, 2004 01:20 PM
BigChris
Nov 7, 2002 11:58 AM
