missing a sensor?
Old Jan 20, 2005 | 06:03 PM
importlegions's Avatar
Default missing a sensor?
got the jdm d15b in no problem, went ot hook up the cx harness to it, and there was a open plug that went to a sensor on the middle back of the cx intake manifold but ont he d15b there is no sensor ther? can i just leave the plug unplugged, or is it somthing more important?
Old Jan 22, 2005 | 06:22 AM
Default Re: missing a sensor? (importlegions)
a friendof mine said it had to do with fuel, ne body kno what the fix is?
Old Jan 22, 2005 | 07:34 AM
locash's Avatar
It could be the purge cutoff solenoid, which normally does not affect performance.. If you can, take a picture of it for us and we can identify it quickly..
Old Jan 25, 2005 | 02:34 PM
Default Re: missing a sensor? (locash)
i found out its the eac valve, and the other vaccuum line goes into the intake manifold but i dont have a spot for it, ne body know what i sohuld do?
Old Jan 26, 2005 | 10:29 AM
does ne body kno?
Old Jan 26, 2005 | 12:55 PM
Katman's Avatar
is this the sensor you're talkin about? (black sensor)
...if so, you can plug your harness to it, but its no needed for your D15 as in you won't get any check engine codes for it.
Old Jan 26, 2005 | 04:28 PM
Default Re: missing a sensor? (K@man)
yes, thank you! j/w do u kno what it does? should i just plug the vaccuum line that goes to it? thanks again someone FNALLY answered my questoin
Old Jan 26, 2005 | 11:17 PM
Katman's Avatar
its smog related, you dont need to use it at all if you don't care about smog issues for the time being. If your D15 has a vaccum port for it on the back of the intake manifold, go ahead and use it, if not, don't worry about it. Your car won't run in limp mode/no check engine lights will come up for it if you completely remove it.
Old Jan 27, 2005 | 01:17 PM
thanks man, yea i dont have the hole on the intake mani. for it, now all i need is a ecu and ill be ready to go!!
Old Jan 27, 2005 | 01:51 PM
Katman's Avatar
TIIIIIIITE!
fishmeister2007
Jun 23, 2009 09:17 PM
andyvaj
Sep 9, 2007 06:00 PM
lude22vti
Jul 10, 2007 04:12 AM
ccivic
Jan 25, 2005 11:34 AM
