mis fire problems
Old Jan 2, 2007 | 09:57 AM
twotonecivic's Avatar
Default mis fire problems
Hey guys, as you can tell I'm a noob to the site. Been doing a little research to see if I can find an answer to my problem, but haven't been able to come up w/ anything yet. I've got a 96 ex civic w/ a 97 b18b1 in it. I've converted back to obd1 w/ a chipped p06 ecu and boomslang harness. I originally put a set of obx stage 1 cams in it and it never ran right. So I figured it could have just been the cams making it run rich. I replaced the cams w/ the stockers and I'm still having the same problem. At idle and steady speeds the car cuts out and misses. I've tried to put new plugs in it which fixes my problem for a few hundred miles then it starts to act up again. I've ohmed all my Accel plug wires to be the same, I've been told to try the o2 sensor, and that didn't fix it. Cap and rotor both look good. Could this be more of a fuel issue than spark? I was wondering if maybe I have a bad injector or something along those lines? I'm running out of options and am limited on tools to just run some tests. It's not throwing any cel's and the car runs strong as long as ur accelerating, but once you get to the speed you want it starts to miss. Anyone have any suggestions. Much appreciated in advance
Old Jan 4, 2007 | 12:07 PM
Default Re: mis fire problems (twotonecivic)
anyone got any ideas?
V3locity
Dec 21, 2009 05:52 PM
Sparkles
Jul 31, 2009 03:27 PM
cyr0ch
Jul 29, 2004 04:58 AM
psycheus
Jul 23, 2004 09:24 AM
91civicEX
23
Jun 4, 2003 08:25 PM
