mild b20 questions...
Old Nov 27, 2001 | 08:55 PM
fowler!'s Avatar
Default mild b20 questions...
Intro: My friend has a fully built LS motor in his EF. Some stuff went bad with the block, so he's thinking of moving up... few questions...
1. Which head gasket to use? B20 or LS...or are they both the same?
2. Will built LS head bolt right on (I'm pretty sure it will)
3. Which timing belt? B20 or B18b?
Thank you much.
Old Nov 27, 2001 | 09:17 PM
Casper1379's Avatar
New User
Default Re: mild b20 questions... (fowler)
Numbers 1 and 3 are the same engine. As well as number 2, the CRV head is an LS head, but with a cam profile that has to flow air for 2 liters, HTH. -Jeff P.
[Modified by Casper1379, 10:20 PM 11/27/2001]
Old Nov 27, 2001 | 09:31 PM
fowler!'s Avatar
Default Re: mild b20 questions... (Casper1379)
So the Ls head and the B20 head are the same thing except for the cams. Makes sense. So there should be no problem....thanks much.
low&slowef
Mar 5, 2011 03:02 PM
Sr420Det
Nov 10, 2010 07:49 AM
SCIVIC94
Mar 3, 2005 06:57 PM
flat-blk-HB
Mar 12, 2002 02:57 PM
