Mid-shaft question???
Old Aug 27, 2002 | 02:58 PM
InfamousRS's Avatar
Default Mid-shaft question???
Im doing a LS swap in my GF's 95 civic. I found a mid-shaft from a 90 Integra. Will this work?
Old Aug 27, 2002 | 03:52 PM
Jeff C's Avatar
Default Re: Mid-shaft question??? (InfamousRS)
i always thought that all b series (90+) manual tranny intermediate shafts were the same. you just need to buy the axles that go with that shaft.
maybe this will help...
http://www.hasport.com/B16axles.htm
i know it is tech for a 4g but it implies what i said
Old Aug 27, 2002 | 04:36 PM
R_yd's Avatar
Default Re: Mid-shaft question??? (Jeff C)
right, you can use it as long as you use the axles for it. too bad if you already have the 94+ axles.
Old Aug 27, 2002 | 07:28 PM
tinkerbell's Avatar
NUP!
teh 1st gen JDM B16A int. shaft will not work on the B16A2/3 engine etc...
it has a different bolt pattern...
i know.
t..
Old Aug 27, 2002 | 07:30 PM
tinkerbell's Avatar
i think so, isnt the LS an Integra engine?
t..
(sorry, im from down-under)
Old Sep 5, 2002 | 05:20 PM
InfamousRS's Avatar
Default Re: Mid-shaft question??? (tinkerbell)
t..
Yes, the LS is from a Integra, I am using a b18b for it though which is from a 94+ teg.
I just went to the wrecking yard today and got a 92 integra mid-shaft for $30!!! Now I just need to get some 90-93 teg axles. I don't have any for a core exchange, so they are really spendy from Napa.
zephon96
Apr 5, 2005 05:53 PM
Engage
Feb 22, 2005 08:24 PM
HatchBox
Jul 28, 2003 12:30 PM
turbotime.
May 3, 2003 02:01 PM
Will Albers
Apr 17, 2002 07:03 PM
