lsvtech spec questions
ok i am getting a jdm b16 head. and i have found a machine shop that will do the work but i need some instructions. i would really like to be able to print out exactly what they need to do. like what hole to plug, where to drill the other hole and so on and so on. also is there anywhere that gives the instructions on how to do it and what head gasket am i going to need.
can i leave my stock internals in or should i do it all at once. and should i get like itr pistons or like je pistons. what else should i know too. sorry for all the questions but i dont know exactly what to do i know the jist but i really need like a site or something to tell me...and i have already looked at crvtech.com and i am doing ls.
thank you guys sooo much.
peace
peace
print this!!!
http://hybrid2.honda-perf.org/tech/lsvtec/howto.html
and if you want it to run nicely, build the block at the same time, the LS has really low compression with a b16 head. CTR pistons are nice for high compression street driving, don't plan to put nitrous, turbo, etc. on with those. do some research. www.jdmhondaparts.com/frameset.htm
[Modified by 88crxoncrack, 5:02 PM 7/14/2002]
i plan to do turbo. so i shouldnt get the head. if not what head should i get.
hey thanks for the link.
thanks for the info.
[Modified by phatcivic99, 8:00 PM 7/14/2002]
If turbo, then keep the head. The only thing you need the machine shop to do to the head is drill the dowl holes. c-speed has a great write up. You can use an allen plug to plug the oil line as long as your comfy tapping a hole (it's really easy-just be sure to clean out the shavings).
You may want to get stainless valves on the exhaust side since the head is off.
[Modified by bruthaboost, 12:40 PM 7/17/2002]
ok so if i plan to do turbo it will be good with the b16 head. now i plan to do work at the same time to save on time and money. now i plan to do a greddy turbo. not sure what it is call...i forgot...haha... what kind of head work should i do and is there any where that will tell me...
to be honest i am not to fimiliar with porting and polishing and boring and stroking. i know kind of what it all does but i could use some help
thanks guys for this great info.
peace
peace
Headwork really depends on your power goals. I think someone on this board pushed 300 whp with the greddy kit plus upgrades. A local shop here promised in the area of 20% increase. I don't know if I'd believe that. The point is to research shops' work and results.
You may want ss valves if you're gonna crank up the pressure so you won't have to worry about burning one. Exhaust only if money is tight.
[Modified by bruthaboost, 12:46 PM 7/17/2002]
what is the best valve for the buck. now i dont care about money but i do you know. i figure if the money i spend is really worth it then i will get it. on this build up i am not cutting myself short. i want the best. but i also like saving money...if that makes sense.
if i talked to a machine shop would they be able to tell me what i should do...i mean will they know what to do with a honda.
thanks guys for the help.
peace
peace
Port and Polish is great for NA apps, but you have so much turbulence with forced induction, its better to put the money in something else now. You shouldn't be burning any valves if its set up correctly.
But Ferrea would be the best. There is a Forced Induction thread about Valves.
With the money that's supposed to go to P&P, you can save for a nice Standalone Fuel management, or other fun toys.
Just for kicks, I have the stock bottom LSVTEC 9.6 CR. Not Horrible for Turbo, but could be lower.
And I'm not in a big rush for Built bottom until I save for sleeving and a new valvetrain. If you've ever seen the LS pistons, they're pretty flat-topped.
I don't know the Timeline of your setup, so you can do whatever you want.
yeah see i was thinking while i have the head out of the car i want to do what i can to it while it is out. i dont care if i dont put it in for a year you know. i just want to do it while it is out. thanks for all the info guys you are really helping.
peace
peace
Here's my setup:
JG Pro series block
Arias 83mm 9:1 Pistons
Eagle Rods
Sleeves
New bearings/washers
Polished and balance crank
GSR Head<-- You name it machine shop has already done it
Ferrea Valves
Ferrea Retainers
Ferrea Springs
Crane Camshafts
STR Cam Gears
STR Sheet Metal Intake Manifold
68mm BBK TB
Custom Turbo Manifold
T63 Turbo
Custom Intercooler
I am still missing:
800cc injectors
Standalone
Roll Cage
Scatter Shield
Crane ignition system.
9/10's here I come.
JG Pro series block
Eagle Rods
Sleeves
Ferrea Valves
Ferrea Retainers
Ferrea Springs
Crane Camshafts
STR Cam Gears
68mm BBK TB
T63 Turbo
Custom Intercooler
I am still missing:
800cc injectors
Standalone
Roll Cage
Scatter Shield
9/10's here I come.
hey guys thanks for the help. i have another question. i just bought a haynes book and it give you the bore and stroke and all and it says standard and service limit. does that mean that is as much as i can do when i machine it. sorry for the dumb question. thanks
That's what the honda recommends. Also spend the money and get the helms. It will be the best 60 bucks you'll blow on your ride. Really.
bakomack
Jul 18, 2010 10:37 PM
speedracer209
Aug 17, 2006 01:10 AM
hott95ej2
Sep 25, 2005 10:35 AM
JDubya
Feb 21, 2003 09:56 AM
