lsvtec pistons??
pick one?
I've heard conflicting stories about running CTR pistons. I was planning on using them in my LS/vtec setup but in discussing that with someone who has built them before I was told the compression ratio would be to high (12.5 to 1) to allow for any type of adjustment using timing. You also would have to worry about what octane gas you are running. I was told that JDM ITR pistons would be better due to a lower compression ratio, around 11.8 to 1 if I am not mistaken.----civichopeful
the CTR's should be good.. its all preference.. the CTR pistons can still use pump gas as long as you arent milling the head or using a thinner head gasket. its safer to run the itr's since its lower compression... but doesnt mean the CTR's wont work in a daily driven car. for conservative drivers/racers.. go with ITR. if you are really into it and are willing to take a car to its limits.. then the CTR is for you.
It's whatever you want to do but I would go with CTR's, with an OE headgasket, no head milling, bored 0.25mm over, and the P72 head with the smaller combustion chamber (41.60cc's) you'll still be fine on pump gas... With my calculations and the parts above your C/R should be somewhere ~12.35:1 Sure you'll have to tune it but right now my friend is building a CRVTEC for his EG and it's going to be running 13.5:1 on 104 octane.... For engine managment he's gonna be running Speed Pro... I see the basic changing point for pump gas to race gas at about 13.0:1 with the proper tuning... So you'll be fine on 91-93.... It basically goes like this with CTR's being the highest OE piston... PCT (CTR) > P30 > PR3 > JDM ITR (P73-00) > USDM ITR (P73-A0) > and then P72-00 > and P72-A0 which i really wouldn't recommend... If you're building an LSVTEC there's no point in going that low... If you have a GSR head then you with either of those JDM GSR or USDM GSR pistons you'll only be in the low to mid 10's..... If i didn't cover anything go ahead and tell me... I don't even know what i just wrote.... hehehe
90-93 is super gas right? im still lost on this gas and piston thing means, but i will read it over !
if i had cr over 13 i have to use race gas?
[Modified by wm5holla, 6:09 AM 2/14/2003]
the CTR pistons can still use pump gas as long as you arent milling the head for conservative drivers/racers.. go with ITR. if you are really into it and are willing to take a car to its limits.. then the CTR is for you.
I put a Ls/Vtec motor together for someone using CTR pistons. It was his daily driven car running pump gas. He has been driving it for months now with no problems.
ok.. there are diff types of Import racing enthusiasts. theres teh guys who want a good motor that they can cruise around in.. and be fast... they arent gearheads... they dont really work on their cars and arent toying around the motor ever...
then theres the racers/gearheads.. they love to race.. take the motor to the limits. know their stuff and familiar with detonation, proper fuel usage, timing, etc.. this is who I will be more comfortable in having the CTR's in.
This is my point of view ok... If guy Type 1 asks me whats best for him... i wouldnt want him to have some high compression motor that he cant take care of. it would be safer to have ITR's in there for him.
lower compression ratio, so you can still go with pump gas...i think CTR pistons hav like 12.5:1 which is a little shady...
CTR pistons increase compression due to their shape (higher dome) and therefore increase the chance of detonation. To reduce the chance of detonation you need to use higher octane fuel and more of it.
DETONATION
Definition: An unwanted explosion of the air/fuel mixture in the combustion chamber caused by excess heat and compression, advanced timing, or an overly lean mixture. Also referred to as "ping".
[Modified by 1BlackHatch, 4:38 PM 2/7/2003]
to those who have built ls vtecs with ctr pistons and B16 heads, did the valve reliefs need to be cut any deeper? what cams were in the motor? it seems like the clearance would be really close.
PR3 (b16a) pistons work really well with decent CR (11.3:1). My friend did a really mild build with PR3's, B16a head, B18A block with GSR cams and put down 173 hp and 135 torque. Plus, you really don't have to worry about pinging with that CR as much as 12:1
