ls vtec questions
is this something i could do or would a shop have to run oil lines or something like that i was told and was told that i couldnt run my b16 pistons or is this not true i really need to know because the block is bare and i would need something to ride on untill i could afford something so could i use the b16 stuff like crank rods pistons ...
any other info would rock because i know zero about hybrid engines
You can use b16, gsr, or type-r pistons. You just have to take the pistons to the machine shop to fit the LS-rods on them. The oil line is very simple. You can buy a oil line kit anywhere between $40-150. You can get better information at http://www.c-speedracing.com (they show you what you need to do)
evilclown312
Jul 12, 2012 08:13 PM
94tegra
Jan 26, 2004 12:16 PM
