ls vtec problem
Old Nov 18, 2007 | 12:42 PM
ludatic98's Avatar
Default ls vtec problem
it has fuel, fire, timing is good, what would cause a car to loose compression on every cylinder at the same time?????
here is the story.......
i have a 95 ls block with a 2000 b16 head in my 92 hatch. the car was running pretty good when i was running the ls injectors in it but it seemed like it was starving for fuel up around vtec. so i put a set of prelude injectors 345cc on it with the restistor box. i am running the hondata s300 with the stock JDM P72 map right now.
anyway i drove this thing all day and it really seemed like it was running quite a bit better...... until this last time i drove it. i was just going down the highway at a normal speed and it just died all of a sudden.
i stopped and tried to start it back up but it sounded like no compression at all. when i got it home and checked it the compression guage wont move on any cylinder. 0,0,0,0.
so my question is: it has fuel, fire, timing is good, what would cause a car to loose compression on every cylinder at the same time?????
Old Nov 20, 2007 | 08:18 PM
skellator_thoj's Avatar
Default Re: ls vtec problem (ludatic98)
recheck your timing again, its good, do a leak down test because it sounds like you have bent valves..
Old Nov 23, 2007 | 08:17 AM
lsvtechatch92's Avatar
Default Re: ls vtec problem (skellator_thoj)
maybe you snapped a timing belt
Old Nov 23, 2007 | 02:12 PM
chad's Avatar
Moderator
timing belt jumped!!! or snapped...
Project ls/vtec
15
May 11, 2019 01:00 PM
bodenman
Feb 26, 2014 02:15 PM
TYPErCRX
May 22, 2007 07:36 PM
cartel420
Jun 26, 2006 03:17 PM
turbo_b16_ex
Jun 28, 2005 06:58 PM
