ls/vtec pistons
Old Mar 5, 2004 | 01:16 PM
tvrcrx's Avatar
Default ls/vtec pistons
I am just starting to get parts together for an ls/vtec using a b18a block and b16a head. I was wondering if since a b20 has the same crank and rods as a b18a, that je pistons for a b20 would work the same in a b18a with a vtec head. This is assuming the block will be sleeved and bored to the proper size. thanks
Old Mar 6, 2004 | 05:27 AM
saleensolution's Avatar
Default Re: ls/vtec pistons (tvrcrx)
are the pistons for a b20 vtec? if you use the strait b20 pistons you will need to fly cut you intake valve reliefs in your pistons because the intake valve are bigger an the vtec heads
Old Mar 6, 2004 | 09:16 AM
tvrcrx's Avatar
Default Re: ls/vtec pistons (saleensolution)
The pistons are made for a b20 vtec.
Old Mar 6, 2004 | 02:21 PM
if you get your block sleeved then i dont really see a problem with it
Old Mar 6, 2004 | 05:04 PM
Newman's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvrcrx &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if since a b20 has the same crank and rods as a b18a, that je pistons for a b20 would work the same in a b18a with a vtec head.</TD></TR></TABLE>
Yes... B20B/Z blocks use the same crank & rods as the B18A/B LS motors. All same internals with an ITR oil pump used on the B20 blocks. As long as the JE pistons are 84mm (or 84.25mm if you're going OS) and are designed to fit the LS rods, then there won't be any problems.
boblaw
Feb 24, 2008 08:49 AM
turbodegsi
Mar 13, 2006 07:43 PM
IntegraGSR(-1)
Jul 30, 2005 03:11 PM
96cxt
Oct 27, 2002 11:34 AM
MrFatBooty
Nov 29, 2001 01:08 PM
