LS VTEC high or low compression?
Old Apr 12, 2005 | 12:49 PM
JDM00SI's Avatar
Default LS VTEC high or low compression?
sup,
i like the idea of an ls block on vtec head. although for the past year ive had in mind that it is a high compression motor that is only for NA. now ive been reading articles of boosted ls vtec motors. am i not getting something here?
If ls vtec is good for boost...then would putting a ls vtec as a NA motor ot be quicker untill you turbo be a good idea? thanks
JDM00SI's Avatar
Default Re: LS VTEC high or low compression? (JDM00SI)
bump
Old Apr 12, 2005 | 08:34 PM
JDM00SI's Avatar
bumpppp
Old Apr 12, 2005 | 09:07 PM
veganej's Avatar
it depends on your level of intensity on your build. some people say vtec isnt good for turbo, some say its fine. do some searches on ls vtec turbo builds and see what problems people had. the main thing you want to be careful of if you are going to do it is oil pressure. as you will have to tap the oil line for the b16 head you will also need oil for the turbo, some people develop oil leaks around the head gasket on ls vtecs. however, i would put in 8.5:1 or even lower compression pistons to reduce your chance of detonation w/ that build. but thats my personal opinion. if you need a b16 head i happen to have one for an ls vtec build i started but aborted. pm if u need one.
Old Apr 12, 2005 | 11:09 PM
Combustion Contraption's Avatar
Medium comp (11.5:1) LS/Vtec here. Head has been pulled twice since original build (7800 miles ago). No leaks since. ARP head studs w/ OEM gasket. Good stuff.
slowwcivic
Feb 23, 2011 06:25 PM
burnitup
May 18, 2005 02:41 PM
torr
Feb 3, 2003 04:22 AM
nighthunt6
11
Feb 10, 2002 08:40 PM
quickLSt
Jul 3, 2001 06:35 AM
