ls/vtec help
Alright so I want to do this swap myself. I see that if I use a golden eagle vtec kit, there is no machining needed. The b16 head that I am using already has already been tapped for oil. I am using a 94 b18b1 block which has the pcv box in the back, besides installing sandwich plate and runnin oil lines what other mods are needed? I know I need a knock sensor, is that gonna be possible to add to my ls block? Or am I gonna have to modify ecu? I already know about wiring vtec components. And what do I have to use honda bond with? I read that all plugs and connections need to be sealed. If tapp is already made and has fitting what else needs to be sealed?
b16-bomber
Nov 8, 2006 05:56 PM
BlueSi2k
Apr 26, 2002 04:52 AM
