Ls vtec help...
Old Sep 28, 2007 | 07:47 PM
swapped95's Avatar
Default Ls vtec help...
I just got everything in the car ready to start and i unplugged the dizzy to prime it...ok everything is fine. I plug the dizzy back in to start it and it still just turns over but wont start up. the timing marks all lined up on the t belt and i move the dizzy back and forth and still nothin...do yall think the dizzy or cap would be bad from sitting for like 2 months??? It worked fine when i pulled it off my car. No check engine light, i pull the plugs and they are slightly wet, like not enough fire, you can smell the gas in the exhaust pipe with a lil smoke, it jumps a bit like its getting fire every now and then while cranking...would my battery being low prevent it from getting good fire....
any help would be appreciated...
Old Sep 29, 2007 | 01:29 PM
swapped95's Avatar
ok so i replaced the cap and rotor and the plugs and still the same thing...i think imma replace the dizzy, maybe the coil is bad...
swapped95
Oct 5, 2007 04:47 PM
swapped95
14
Sep 29, 2007 10:26 PM
swapped95
10
Sep 29, 2007 09:01 PM
swapped95
Sep 29, 2007 01:29 PM
swapped95
Sep 29, 2007 01:28 PM
