are the ls/vtec conversion kits legit?
Old May 24, 2005 | 01:06 PM
auburnBoy's Avatar
Default are the ls/vtec conversion kits legit?
i see all these ls/vtec conversion kits for sale that are suppsoed to involve no machining in order to provide oil to the head. they claim it only takes 10 minutes to set it up...any input??
Old May 25, 2005 | 08:13 AM
Evil-EK's Avatar
Default Re: are the ls/vtec conversion kits legit? (auburnBoy)
Golden Eagle makes a great kit. It comes with all the hardware you need to bolt the head to the block hassel free. If you would like I can get you one from the shop where i work for 229.99. Just give me a call @ 1-800-826-9843. My name is Billy.
Old May 25, 2005 | 05:55 PM
VTECVillain's Avatar
If you buy the Golden Eagle kit, it's definitely worth it unless you really know what you are doing and can source the parts individually or use other methods. It's going to take a lot more than 10 mins. to put it install... I mean seriously it's hard to do an oil change that quick which is part of the procedure. I wouldn't say that the kit speeds up the process too much, it just makes it a lot easier for the do-it-yourselfer.
Old May 26, 2005 | 12:13 AM
auburnBoy's Avatar
Default Re: are the ls/vtec conversion kits legit? (BigBlockH22atch)
thanks dude i will
Old May 26, 2005 | 12:15 AM
auburnBoy's Avatar
Default Re: are the ls/vtec conversion kits legit? (VTECVillain)
thanks for the help. if i wanted to take my car in and let someone else do my oil change would there be special instructions id have to give them for an ls/vtec or is it still the same as always?
Old May 26, 2005 | 05:20 AM
dohcdelsol93's Avatar
The oil filter screws on the pancake just as it would the engine.
GE ls/vtec kit
Old May 26, 2005 | 07:35 AM
Evil-EK's Avatar
Default Re: are the ls/vtec conversion kits legit? (dohcdelsol93)
No special instructions. It uses the same oil filter as any honda.
Old May 26, 2005 | 09:02 AM
auburnBoy's Avatar
you mean i have to buy another oil filter and screw it onto the outside of the motor where the pancake is?
Old May 26, 2005 | 09:11 AM
Evil-EK's Avatar
The kit comes with a sandwithch plate that screws on where the oil filter use to be, then the oil filter screws onto the sandwitch plate. Not a big deal. when you buy the kit you will see what I mean.
jimburt3rd
Dec 19, 2008 10:49 AM
TunerToys
May 18, 2008 10:04 AM
CSSMiketsi
May 16, 2008 09:26 AM
modifyORdie
Jan 3, 2006 02:31 PM
peenut4head
Sep 29, 2004 07:31 PM
