ls cable trans with b16 shift linkage
Old Mar 13, 2005 | 03:19 PM
hybridpatient95's Avatar
Default ls cable trans with b16 shift linkage
im wondering if this combo would work.. and what axles would i need to use for the ls trans to work in a 91 crx hf.. thanks guys
Old Mar 13, 2005 | 04:50 PM
ghkjghkgh
Old Mar 13, 2005 | 06:53 PM
VTECVillain's Avatar
Default Re: ls cable trans with b16 shift linkage (frankenfiend 04)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by frankenfiend 04 &raquo;</TD></TR><TR><TD CLASS="quote">im wondering if this combo would work.. and what axles would i need to use for the ls trans to work in a 91 crx hf</TD></TR></TABLE>
The LS cable tranny will work fine with a B series motor, but the B16 linkage will not work unless you cut it, reweld and make it work. As for the axles, it's best to use a 90-93 Integra intermediate shaft and axles.
Old Mar 14, 2005 | 03:25 AM
ooh ok thanks man... so i can only use ls shift linkage? is there anything else i can use?
Old Mar 15, 2005 | 05:51 PM
Default Re: (frankenfiend 04)
There isn't a direct fit linkage for a B series EF swap. You can use a DA Integra linkage or JDM EF B series linkage but either way they will have to be cut and rewelded to fit. You should buy a linkage from the manufacturer of the mount kit you use.
Old Mar 16, 2005 | 03:14 AM
thanks.. i got hasport mounts now i gotta get some hasport shiftlinkage..
bubba3369
Aug 30, 2009 07:14 PM
cars101
Sep 5, 2007 06:57 AM
SoHc94
Jan 26, 2007 06:23 AM
Fezzie
Aug 16, 2006 09:09 AM
crunkedhatchbacks
Feb 9, 2006 04:27 PM
