low rpm studder?
Old Apr 14, 2004 | 06:56 PM
renzema's Avatar
Default low rpm studder?
Okay I'm not sure if this is the forum to put it in but what the hell.
I have a 92 civic HB, I dropped a lsvtec into it and its been in there for about 2 years now, but as of just a month ago I am having a HUGE problem with a studder between 1k-4k rpm's, there is no pinging or anything, still idle smooth and only does it on occasion not every time. There is no major work done to it(head:type-r cams,pnp,shaved....block:stock tranny:GSR w/ drag clutch). At first I thought it maybe in need of plugs and wires, did that no affect. Then I thought maybe the fuel filter, still nothing. I have ask mechanics and all at a loss, wondering if anyone out there can help me out. If I haven't supplied enough info just ask and I will response asap.
thanks
Old Apr 14, 2004 | 07:44 PM
SAVIOVEGA's Avatar
Default Re: low rpm studder? (renzema)
That is similar to what mine is doing. In neutral, if I give it a little gas it hits like a rev limiter around 2k RPM. It just bounces back and forth. Give it a little more gas and it is fine. If it's is gear, it won't do this. WTF???
Old Apr 14, 2004 | 08:22 PM
Ddogz15's Avatar
Default Re: low rpm studder? (SAVIOVEGA)
running rich ? had a little problem with mine with bogging out due to running rich..also, i had put an o2 simulator instead of the one on my cat cuz i only run a test pipe, i did both of these at the saem time and it cured my problem, so i duno? trial and error
Old Apr 14, 2004 | 08:45 PM
renzema's Avatar
could getting it tuned fix this problem? I have yet to tune it but if this will could be the problem I would be more than willing to do it.
I also have no cat, I custom made my exhaust so I just never created a place to mount the cat.
anyone else?
JR
Old Apr 15, 2004 | 04:14 PM
renzema's Avatar
Default Re: (renzema)
okay well checked the timing today and all is well there.
SOOOOO anyone know what it could be? I have shops telling me i need to install a controller(considering a hondata), and then I would do a dyno day, but I want to exhaust all other options before doing that.
thanks
JR
Old Apr 15, 2004 | 05:34 PM
95240sx2jz's Avatar
have you checked all your vacuum lines? they can make a car do some crazy things, especially at lower engine speeds.
Dane
Old Apr 15, 2004 | 05:49 PM
renzema's Avatar
Default Re: (95240sx2jz)
hey never thought of that, will do, don't think it would be since listening to the car you don't that normal hiss from when you miss a vaccuum line, but a possiblilty. Also unless one brock this wouldn't be the problem. I really think its fuel, just seems to act like it is either getting far to much gas or not a enough
anyone think that it could be a clogged injector?
thanks
JR
Old Apr 16, 2004 | 11:01 AM
Ur 2 Slow 4 J's Avatar
check the EGR and make sure its not plugged in. i had sometihing like that too. its a round cylinder by your fuel rail
Old Apr 16, 2004 | 11:14 AM
renzema's Avatar
Default Re: low rpm studder? (Ur 2 Slow 4 J)
okay will do, I think it maybe the o2 sensor so I order a new one, it was due anyways. So we will see if that fixs the problem.
thanks
JR
blue2006civic
Honda Civic (2006 - 2015)
Jun 17, 2015 06:13 PM
llTysonll
Sep 12, 2005 03:29 PM
renzema
11
Apr 15, 2004 11:51 PM
renzema
Apr 14, 2004 04:32 PM
Sirvtec
Feb 10, 2002 03:21 PM
