KS Code 23. (Searched)
Old Sep 30, 2006 | 05:41 PM
beoy9's Avatar
Default KS Code 23. (Searched)
Hey guys, I just got finished with my swap, and just after driving it around getting into it, everything is fine. But, I hit the revlimiter in first and the CEL came on. I got it back home and it's the KS. I've searched all over these boards, but can't find anyone with my situation. I mean the second it hit the rev limiter it came on. Is this due to bad timing, faulty KS or KS wiring?
I've verified the KS wiring from the plug to the ECU, reset the ECU and I'm still pulling the code. Did hitting the rev limiter destroy the sensor?
Please help
Edit: I'm driving a 95 DX with a JDM B18C GSR motor. Using my DX harness with a Rywire sub harness
Old Sep 30, 2006 | 09:25 PM
beoy9's Avatar
Ok, an update: I had my friend come over and he's looking at this with me. We've got the CEL to clear but it keeps coming on. The timing seems to be alright, but here is the weird part. My friend doesn't seem to think i'm hitting VTEC. It's revving all the way up no problem, and it will for about 45 seconds or so but he says he doesn't hear it. I don't know personally because this is my first VTEC car. After about 45 seconds of driving the CEL comes on and it goes into limp mode. If I shut the car off, then restart it, the CEL goes off and it's out of limp mode, but still no VTEC. Once we get back to my place, it's always pulling Code 23, Knock Sensor. =/
Please if anyone has a clue, fill me in!
Old Oct 1, 2006 | 06:36 PM
egsleepercivic's Avatar
did you use shielded wire for the knock sensor ?
Old Oct 2, 2006 | 06:18 AM
poison's Avatar
Default Re: KS Code 23. (beoy9)
If you checked continuity with the wire, then the sensor is bad.
beoy9
Oct 5, 2006 11:29 PM
beoy9
Sep 30, 2006 09:24 PM
spyderracing
Sep 30, 2004 05:59 PM
99931238
Jun 9, 2004 05:28 PM
