JDM or USDM engine
Old Aug 23, 2001 | 10:50 AM
gsrcivic20's Avatar
New User
Default JDM or USDM engine
Ok I am in the process of buying a 94-95 Gsr engine for my '92 Civic Si--What I want to know----is there any difference between the jdm and usdm version of the motor other than the wiring harness and that extra horsepower etc ----what do you all think would be a better and a easier install to do----
Old Aug 24, 2001 | 09:09 AM
SoloSol's Avatar
Default Re: JDM or USDM engine (gsrcivic20)
The usdm will be the easier of the swaps to do. I am in the process of doing jdm b16a hydro swap and I tell you from experience that I would go with the usdm motor if I was to do this again
Old Aug 26, 2001 | 09:36 AM
gsrcivic20's Avatar
New User
Come on is anyone else going to post something?????? [IMG][/IMG]
Old Aug 26, 2001 | 01:57 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
stock for stock...the j-spec is better, but if youre concerned about being able to say, "shyah dude, my engine is from japan man". so, who cares...build a usdm. a car is only as fast as you make it ergo, anycar can be fast meaning any engine.
Old Aug 26, 2001 | 02:09 PM
Jared's Avatar
They will both wire up the same, the JDM version will have slightly more hp due to the higher c/r. Just get whichever one is easiest and cheapest to get.
Old Aug 26, 2001 | 02:57 PM
Katman's Avatar
Default ..word..
yeah the US B18C and JDM B18C are 94% the same ....
only differences are the pistons, cam profile (JDM cams are a bit better but not much), and stock ECU program - actually the JDM B18C P72 ECU has a shitty program, you're better off with a US P72 ECU. Oh yah, the block stamp reads:
(JDM) B18C
(US) B18C1
..but if you're one of the **** type that is a total worry bug when it comes time to smog your civic, make sure you get a US B18C1 that is the same year or newer and get it ref'd.
You can run a US engine harness on a JDM B18C... no problem.
Old Aug 26, 2001 | 09:15 PM
Civicboy's Avatar
Default Re: ..word.. (Katman)
I am leaning towards USDM for my swap just because I will not have to go through the pain of tracking down a USDM ECU. I will have the "good" ECU and can put some JDM ITR or CTR cams and pistons and run higher compression than a JDM motor.
Old Aug 27, 2001 | 08:28 AM
Katman's Avatar
Default Re: ..word.. (Civicboy)
way ta go..
Old Aug 31, 2001 | 10:10 PM
gsrcivic20's Avatar
New User
thanks for the info----Does anyone else have anything they want to add
Old Aug 31, 2001 | 11:58 PM
MyDadsATerrorist's Avatar
New User
Default dyno results for jdm or usdm motors...
http://www.importreview.com/main.html
Old Sep 1, 2001 | 12:41 AM
MiraiZ's Avatar
silly question
Old Sep 2, 2001 | 01:06 AM
brad.'s Avatar
Default well.....
i would go with a USDM engine for the simple fact that you would be able to smog easier the with a JDM engine...
i am going through this dilemma!!
how can I smog my JDM b16?!?!?
this sucks elephant *********
Old Sep 2, 2001 | 02:00 PM
silverhybrid's Avatar
New User
if u cant find a usdm gsr ecu......since u have a 92 si (p28ecu) get it chipped..
Old Sep 11, 2001 | 05:24 AM
gsrcivic20's Avatar
New User
Default Re: JDM or USDM engine (silverhybrid)
Carboyracing.com
Old Sep 11, 2001 | 07:31 AM
Kalokohan's Avatar
New User
I would go with USDM for the simple fact that it is easier:
A. To pass emissions
B. To find an ECU
C. To track the VIN number
D. To find parts
E. To stay legal
Old Sep 11, 2001 | 01:32 PM
Bumnah's Avatar
Default Re: JDM or USDM engine (Guardson3r3)
I'd go with the JDM setup.
Cheaper to get
Easier to get
more potential.
i also don't live in California so Idon't have to worry about smog and such.
so i guess i have it easier than you
Old Sep 11, 2001 | 07:04 PM
b18b1slmd3dr's Avatar
New User
Default Re: JDM or USDM engine (Bumnah)
USDM all the way, Not all JDM motors Have 30000 miles on them, plus alot are HEAVILY abused.
Old Sep 12, 2001 | 05:28 AM
Kalokohan's Avatar
New User
If you live in Cali, it should be easier to get a JDM engine since Japan is right across the water. I live in VA, so the engine has to travel across the Pacific, then across the nation. I gots my USDM B18C1 00' motor with 9K miles from North Carolina, shipping was cheap.
Old Sep 12, 2001 | 08:31 PM
Bumnah's Avatar
I'm in VA also. There are actually importers here in VA that import JDM motors.
I think some warehouse in Northern VA somewhere has lots of JDM motors for sale. I'm talking Nissan motors, 3 rotor mazda motors, skyline motors, and ofcourse the Honda motors.
My friend has the guy card. Hybridin' is getting very big in VA.
Old Sep 13, 2001 | 06:16 AM
Kalokohan's Avatar
New User
I might have to hit you up them Bumnah, I live in Fairfax and I need to get a hold of some mugen parts without getting raped.
PIntegraMP
Apr 9, 2006 02:25 PM
i_HeArT_EgS
15
Jan 19, 2006 06:31 PM
94lsboost
Oct 27, 2003 03:16 PM
SlipoftheCondom
Nov 26, 2002 09:08 PM
