JDM H22a OBD1 Dizzy to OBD2a (Throwing Code 9)
Old Oct 2, 2011 | 06:55 PM
Mfoehrkolb's Avatar
Icon3 JDM H22a OBD1 Dizzy to OBD2a (Throwing Code 9)
I have a JDM H22a swap... OBD1 internal coil dizzy, and i converted it to obd2a to match my obd2a civic harness...
I just started it tonight for the first time in about 6 months and i am throwing code 9.
Why am i throwing code 9? I am 95% sure i had all the correct wiring done... So what causes this considering my situation.
EDIT: Forgot to add, its a 98 civic, 98 harness, obd2a to obd1 step down, phearable chipped p28...
Old Oct 3, 2011 | 04:40 PM
Mfoehrkolb's Avatar
Default Re: JDM H22a OBD1 Dizzy to OBD2a (Throwing Code 9)
UPDATE: I tested the p28 in another h22 hatch today and it started right up and no cel.
My 1998 HX harness didn't have a ground pinned in for the CYP ground, so i pinned one in and grounded it out. Still got the code 9... I checked my obd1 to obd2a conversion on my dizzy and everything checked out fine. I shortened the wires and redid them just help out with the ohm reading but the cyp sensor ohms out within spec.
I am really at a loss atm because i don't know what is wrong. The dizzy worked fine last time i used it. (before i tore out the motor and rebuilt)... So i am doubting that the dizzy went bad.
What would cause this problem? I really tried diagnosing the problem but idk what else to do.
Old Oct 4, 2011 | 08:54 PM
Mfoehrkolb's Avatar
bump!
Old Oct 6, 2011 | 10:13 PM
Mfoehrkolb's Avatar
bump iirc.......
Old Oct 8, 2011 | 06:39 AM
92lxsleeper's Avatar
dizzys can randomly go bad tho. i went out one mornign a year ago and my car wouldn't start. turns out the coil failed overnight.
Old Oct 8, 2011 | 04:01 PM
Mfoehrkolb's Avatar
--- I am leaning towards something happening when i rewired the plug from obd1 to obd2a. Maybe i shorted the senor out if i didn't ground myself out etc. Or when i was soldering everything together and shrink wrapping it.
The car starts and runs totally fine... Just the code, and no inspection or emission for me with a code on. So it needs to be resolved.
Old Oct 17, 2011 | 12:19 PM
Mfoehrkolb's Avatar
New TD89 Dizzy solved the problem. OBD2a internal coil with all sensors in dizzy. win.
Sns8504
Oct 22, 2017 05:56 PM
99y8
Sep 9, 2012 09:31 PM
complexr
Jul 13, 2009 08:02 PM
SuicideSlide
Nov 4, 2004 03:31 PM
