jdm b18c guru's
Old Nov 11, 2002 | 06:51 AM
sleeprhatch's Avatar
Default jdm b18c guru's
I am 90% done on my wiring for my 99 jdm b18c going into my 98 ek.
Q In my Helms manual for a usdm b18c5 connector C (31p) pin 9 is a FAS pinout. My ek ecu connector C (31p) pin 9 is TMV but my engine was not wired for it. Do jdm engine need this wire? if so what is this?
Q. being a jdm engine i know it does not look for
crankflucuation sensor
v-tec pressure switch
is there anything else it does not look for....like evap sensors?
Old Nov 11, 2002 | 09:21 AM
Default Re: jdm b18c guru's (sleeprhatch)
Old Nov 11, 2002 | 10:41 AM
Kataku2K3's Avatar
Okay well the FAS and TMA are the same thing... When i did my friend's GSR swap into his '96 hatch it has the wire for that.... Being the same loom as you ('96-'98) it should have it.. Or are you using the 99+ (OBD2b) EK loom? What ECU are you running?? I knew about the VTM on the JDM motors didn't know that the ECU's didn't look for a CKFS!! Guess ya learn something new everyday.. Latez
Old Nov 11, 2002 | 12:46 PM
i am using the 98 ek harness with a jdm p73. there are 3 engine types for the ek i have a d16y17 block. in which there is no wire avaliable for this. any how if i must i will add this wire, but what to? stupid harness this is the only hold up i got rrrrrrrrrrrrrrrrrrrrrrrrrr.
[Modified by sleeprhatch, 9:47 PM 11/11/2002]
Old Nov 11, 2002 | 03:25 PM
Old Nov 11, 2002 | 11:23 PM
Kataku2K3's Avatar
You know man, I don't really know... When I did this swap for my friend i wrote up all my own wiring diagrams because I didn't have any at the time. When I had to figure out what to swap around I realized that i didn't have to do anything with it... I have never even otherwise heard of FAS and TMA for anything.... I'll look into it more and try to find out some more info... Latez
Old Nov 11, 2002 | 11:26 PM
Kataku2K3's Avatar
Default Re: jdm b18c guru's (JDMspecEG6)
You have an EX harness then right?? When I did I reworked the DX which was a lot more fun than yours.... I wouldn't think that they would change anything for the FAS and TMA but i don't know.... **** this sucks!
Old Nov 12, 2002 | 10:22 AM
i got a cx harness on my car. could this FAS and TMA do something with auto transmissions? i have a stick shift. this fkn harness sucks azz. thanks anyway. seems like YOU ARE THE ONLY GUY WHO HAS DONE A SWAP HERE!!
Old Nov 12, 2002 | 02:10 PM
Kataku2K3's Avatar
Hahaha yea right.... There's a grip of people that have done this swap so someone has to know.... I wouldn't think that it is for auto but who knows.... Plug C has a lot of weird wires in it that i'm really not sure of.... I see its main purpose being distributor sensors, VTEC pressure, etc... The normal ****.... I'll keep lookin into it. Peace
Old Nov 12, 2002 | 05:48 PM
thanks buddy
i will also
Old Nov 12, 2002 | 07:04 PM
-Darren-'s Avatar
you should IM hxman and tonyxcom, they seem to be very helpful with stuff like that.
Old Nov 12, 2002 | 07:35 PM
tonyxcom's Avatar
Default Re: jdm b18c guru's (star&buc)
I dont think you need to worry about pin 9 at all. Or at least don't worry about it untill you throw codes.
The JDM ECU wont require the following,
VTEC pressure switch
CFK (Crank fluctuation sensor on oil pump)
PTANK (Fuel Tank preassure sensor on gas tank)
SHO2S (Second O2 Sensor)
I wouldn't worry about anything until you get codes, that way you only need to worry about what isn't actually working.
If this helps, I am using a 96-98 EX harness on my 2000 USDM ITR swap. I didn't have to do ANY repinning at the ECU for my 96(JDM) P73 to work correctly and not throw any codes. But I did make some pinning changes on some of the plugs, I am almost certain it was the IAT sensor (just swapped pin 1 for pin 2).
Here is the Helms info for a 96-98 EX Ecu and harness in case it may help.
http://www.we-todd-did-racing.com/we...MxeTU0MQ%3D%3D
[Modified by tonyxcom, 4:36 AM 11/13/2002]
Old Nov 12, 2002 | 07:40 PM
*****bows Down**** thank you for the info i can FINALLY sleep
martiniracing
21
Dec 5, 2009 10:55 PM
GreddyCivic7
Jan 10, 2006 11:36 AM
TK715
Nov 3, 2003 08:14 AM
