jdm b16a gurus, please help!!!!!
Old Aug 19, 2002 | 10:40 AM
stockegsix's Avatar
Default jdm b16a gurus, please help!!!!!
did the search but didnt get enough information. i need all your help.
ok i have a jdm b16a 5series in my 6thgen coupe, i'm using all 99 si mounts and gsr axles, shift linkage and tranny. i'm putting everything in a 92 cx hatch, what do i need. peace
axles?
mounts?
harness?
ecu?
Old Aug 19, 2002 | 10:57 AM
Kamin's Avatar
Default Re: jdm b16a gurus, please help!!!!! (silversleeper)
all the same stuff excet the ecu i belive.
edit: unless its a p30 with obdII to obd1 conversion.
[Modified by KAMiN, 11:58 AM 8/19/2002]
Old Aug 19, 2002 | 11:44 AM
stockegsix's Avatar
Default Re: jdm b16a gurus, please help!!!!! (KAMiN)
i'm not so sure about the mount next to the timing belt. will a 94-97 gsr mount work?
Old Aug 27, 2002 | 03:31 PM
vivid02's Avatar
yes it will.
Old Aug 27, 2002 | 04:12 PM
Styles's Avatar
Default Re: jdm b16a gurus, please help!!!!! (vivid02)
you need a 94+ Integra rear tranny bracket and 94+ Integra cast bracket that goes into the block inside the timing belt and then you will use a 94+ Integra mount on that side....or we sell that mount in a billet replacement with solid urethane if you wanted something stiffer ....oh and you will need OBD1 electronics
[Modified by Styles, 1:12 AM 8/28/2002]
kpop
Jan 20, 2007 09:20 AM
mraudio13
Feb 13, 2003 05:27 AM
sushibug
Jan 16, 2003 12:53 PM
. o 69 o .
Jan 17, 2002 10:49 AM
