ITR tps sensor
I have a 1998 Integra GS and I'm looking to put a ITR throttle body on. The only problem is that it's missing the tps sensor. I was wondering if my tps sensor is the same and could I swap them?, or do I have to buy a ITR tps from a junk yard?. Would civic tps work also??
If it's USDM then it is held on with rivets but you can take a dremel and slot the rivet and unscrew it and put it back on with normal hex head screws like the JDM ones. And yes your TPS will swap over no problem
They are not rivets. They are screws with heads that break off when you get to a certain torque. This is to prevent tampering. However, as someone already mentioned above, all you need to do is slot the blind head of the screw, and take them out with a slot screwdirver. I usually do it carefully with the hacksaw.
SiMateoAko
May 28, 2006 01:44 PM
