ITR Header.
does the JDM spec ITR exhaust manifold bolt up to a b16 head?
I'm about 99% sure it does, but can I get that extra confirmation from someone?
thanks in advance.
thanks in advance.
All B-series headers/exhaust manifolds have the same bolt pattern... D-series is close if you mill it out a tad but that's ghetto. Your JDM ITR header will fit your B16 head, but the 2.5" collector won't fit your stock cat.
ugh.
b18a intake manifolds won't bolt to a b16 head, thats all IO knew for sure (a friend once told me)
Well, I was trippin because I bought a full head gasket set for a b16 and the exhaust manifold gasket doesn't line up to the studs on the head.
yet the intake manifold gasket works fine... all the holes line right up.
any suggestions. what gasket do you guys use???
Modified by 89s1 at 6:08 AM 3/31/2004
Modified by 89s1 at 9:10 PM 3/31/2004
so my problem was solved today.
went back to the dealer and got the proper gasket.
A D-series gasket was packaged in my set so they replaced it with a GSR 2-ply metal manifold gasket for me.
everything is peachy
nexgen91
Feb 25, 2007 09:47 PM
RTW DC2R
Jun 3, 2006 09:50 AM
JDMkidGSR
14
Feb 7, 2006 08:22 PM
