Intermediate Shaft Bolts
Old Dec 19, 2002 | 09:27 PM
tyler's Avatar
Default Intermediate Shaft Bolts
Finally got the ZC intermediate shaft but need bolts that mount it to the block, Will the bolts from any shaft work? If not anyone know where I can get the right ones?
Old Dec 19, 2002 | 09:49 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Intermediate Shaft Bolts (tyler)
not just any bolt will work, the sizing is different, there should be 3 bolts, 2 upper and one lower, the one lower is about a half inch or so longer then the upper ones. good luck man.... Ron
Old Dec 19, 2002 | 10:05 PM
Chiclets's Avatar
Default Re: Intermediate Shaft Bolts (SIXTYdashONE)
save ur self the trouble of looking for them and just go to the dealer and get them for like $5-$8 each. they will be perfect fit and no second guessing and no risk of putting in the wrong tread bolt in there and striping the treads
Old Dec 20, 2002 | 02:14 AM
tyler's Avatar
Default Re: Intermediate Shaft Bolts (bluedemon)
Bluedemon which dealership do i go to acura or honda? honda doesn't have a listing for a DOHC d series block. Do you know if the bolts from 86-89 integra will work?
Old Dec 20, 2002 | 08:21 AM
im_poor's Avatar
junk yard maybe....
Old Dec 20, 2002 | 09:46 AM
92sleepR's Avatar
New User
The bolts are specific. They have a shoulder, just under the head that fits tightly into the flange holes to accurately locate the shaft. You should be able to get them from Honda pretty easilly.
Mike
Old Dec 20, 2002 | 09:04 PM
riceboy's Avatar
perfect answer
yes, use 88-89 teg bolts...if im not mistaken.....verification anyone?
[Modified by riceboy, 6:04 AM 12/21/2002]
Old Dec 20, 2002 | 09:25 PM
Cm91h22a's Avatar
Default Re: Intermediate Shaft Bolts (riceboy)
as far as i know, all intermediate shaft bolts are the same.
Old Dec 20, 2002 | 10:59 PM
madtownhonda's Avatar
Default Re: Intermediate Shaft Bolts (Cm91h22a)
This is correct...they are all the same size bolts.
tempsohc
May 14, 2009 01:08 AM
rick_rabies
Mar 23, 2009 01:26 PM
jweeks
Apr 16, 2007 06:39 AM
StreetRacinThug
Mar 27, 2006 09:29 AM
MeanGreenEG9
Jan 13, 2003 08:17 AM
