insight B-Series swap
Old Aug 4, 2004 | 08:14 AM
dohcbag's Avatar
Default insight B-Series swap
has anyone attempted a b-series swap into an insight?? i loved my light little car and i want to give it a major increase in power
Old Aug 4, 2004 | 09:03 AM
JDMotive's Avatar
Default Re: insight B-Series swap (juanpwnz88)
Im not sure if anyone has done the swap,but there are a few people who have done k series swaps into the insight.
Old Aug 4, 2004 | 10:17 AM
dohcbag's Avatar
Default Re: insight B-Series swap (JDMotive)
well... even better!! does anyone have information on where to buy mounts, ecu conversions, etc?
Old Jul 23, 2014 | 10:32 PM
JJsMotorsports's Avatar
My build, my b series turbo build. Under construction.
Old Jul 24, 2014 | 05:23 AM
spAdam's Avatar
Loved
Community Favorite
$$$ if you want it nice.
http://www.lhtperformance.net/docume...t_k-sight.html
Old Nov 12, 2016 | 09:34 PM
BongoBennie's Avatar
I can't say for B series as that would be a tough one for most to pass emissions with,
I am currently swapping in a Fit motor but I can she some light on the knuckles for you.
You can use EM2 civic knuckle for 4 lug or RSX/EP3 for 5. With shims you can use stock shocks or like most, use an rsx type coil over as well, the steering arm is a bit higher but works. You will have to modify either the stock lower control arm or the knuckle as they both have the ball joint attached. There are a few builds on insightcentral.net but as you will notice, everyone does it a little different. When you have it figured out that far, call Insane Shafts or Driveshaft shop for axles.
Im having these machine fit into my control arms, some use a similar product on the knack instead
https://www.kingmotorsports.com/p-43...t-inserts.aspx
lj0334
Mar 21, 2017 11:22 PM
raverx3m
45
May 14, 2013 08:44 PM
Goldiehonda
15
Mar 20, 2013 10:17 PM
Joni Teppo
10
Nov 24, 2012 04:44 PM
mrDFWmechanic
Feb 15, 2004 07:15 PM
