innovativemounts
Old Feb 4, 2012 | 08:05 PM
playlife's Avatar
Default innovativemounts
is there anyone doing h22 swap with the Innovativemounts combination( IM mount and IM axles)? will the binding issue can be clear by using the IM axles and the IM mounts.
goggle and found another problem is the axles will hit the shock fork because the motor will move forward abt 1"............it that true?
anyone that doing or already done with this IM combination swap please give some advise and comment.........
thanks
Old Feb 12, 2012 | 02:19 AM
playlife's Avatar
Default Re: innovativemounts
bump for advise and sharing
Old Feb 15, 2012 | 06:53 PM
Krut's Avatar
I used to have a straight h22 swap in my car and I used the innovative h22 into EG mount kit with driveshaftshop h22 swap axles...worked fine later found out the H2B is a far superior setup to have in a civic with an H22
Old Mar 2, 2012 | 07:50 PM
Lockner13's Avatar
I used 89 integra axles on both sides with prelude half shaft and h22 inner CV cups on me EK hatch, but note that I am using the M2B4 LSD trans thats a bit bigger. I left the complete 89 integra axle minus the inner cup on both sides! I moved it today for the first time and it seems ok so far no binding or popping/shaking. I tried the 90 integra passenger side axle and it wouldn't work for me at all.
rmnS2K
Transmission & Drivetrain
Oct 5, 2008 06:39 PM
dc2_poojan
May 18, 2008 09:19 AM
hpi247
Apr 11, 2007 04:19 PM
AnclyT
Feb 10, 2007 04:42 PM
civic.tar.gz
Feb 17, 2003 08:25 AM
