Injectors Problem
Old Apr 27, 2007 | 03:01 PM
95civicB16's Avatar
Default Injectors Problem
Ok here is my set up. 95 civic with a p28. I have a b16 that i believe is obdo. The motor had a conversion harness to go from obd0 to obd1... I am using my 95 civic wiring harness so I cut and soldiered the old injector plugs into place. Ok the old motor has a resistor box. How can I tie in the resistor box with my factory harness. I have the resistor box and plug but I don't know were to run the wires. Can some one help thanks.
Old Apr 28, 2007 | 02:00 PM
95civicB16's Avatar
Default Re: Injectors Problem (95civicB16)
Oh come on guys i know some one here knows what i am talking about. Oh yea BUMP
Old Apr 28, 2007 | 05:05 PM
kevinz's Avatar
obd1=no need for the resistor box, search:b series swaps
Old Apr 28, 2007 | 05:52 PM
95civicB16's Avatar
Default Re: Injectors Problem (kevinz)
The injectors are obdo.
Old Apr 29, 2007 | 09:31 AM
kevinz's Avatar
I think you will have better luck converting everything to at least obd1 but if you don;t goodluck with the mismatch stuff,,,,,,,, search "dsm injectors", there write-ups for the injector box in details,
Old Apr 29, 2007 | 09:43 PM
95civicB16's Avatar
i have a set of obd1 injectors but they are d series... that is why i was going to go with obdo because of more rate.
Old Apr 30, 2007 | 06:25 PM
kevinz's Avatar
D-series vtec injectors and B-series injectors are the same 240cc,,,,,,,,or unless they are a set of non vtec d-series ,180 or 190cc
Old Apr 30, 2007 | 08:45 PM
95civicB16's Avatar
They are both the same man i would have never guessed. I guess I will put the d series on the b16 and change the plugs back lol always something. Well that will keep me from wiring in the resistor box. Hey I appreciate the comments thanks.
Old May 1, 2007 | 02:04 PM
kevinz's Avatar
No problem, yes put the d-series in, and good to go. Good luck and let me know if there anything else I can help you with.
lilsicsoul
Mar 1, 2009 04:23 AM
DjBurns
Aug 5, 2008 07:19 PM
Maxcapacity
Jul 6, 2008 06:46 PM
makoto
Apr 11, 2007 10:38 AM
7rrivera7
Jan 17, 2005 02:07 PM
