Injector wires
Old Sep 14, 2012 | 09:37 AM
thundernoodle's Avatar
Default Injector wires
Im swapping an OBD2 GSR into a 90 DX. Im using the OBD2 injectors and I have a spare wire from each injector. Im not using a resistor box, so do I wrap all the spare wires togeather and just leave them? Do I ground them to the car?
thanks
Old Sep 14, 2012 | 09:45 AM
Default Re: Injector wires
I also have a spare wire coming off the IAB and the VTEC oil pressure switch. Are these grounds or can they just be cut?
Old Sep 15, 2012 | 04:53 PM
Maybe move this to 88-91 Civic section?
Old Sep 16, 2012 | 10:43 AM
94EG8's Avatar
Seagull Management
the 4 yellow/black wires all get connected together and then go to 12v switched ignition power. the brown, yellow, red and blue wires go to the ECU.
Old Sep 16, 2012 | 02:10 PM
Im using a swap harness so the red, blue, brown wires were already wired. Could I run them to any 12v source, like the VSS power or batt?
Old Sep 16, 2012 | 04:07 PM
94EG8's Avatar
Seagull Management
You can probably run them to VSS power, on a stock harness VSS power and the injectors power wires and a few other things go into a junction connector (block off plug) where they're all connector together. Don't connect them to battery power though, you don't want them drawing power with the key off.
Old Sep 16, 2012 | 04:11 PM
Ok so as long as the power is from a 12v thats not "constantly" on it will be good? I only need one 12v to be powered and the others will be powered enough?
thanks for your help
Old Sep 16, 2012 | 04:20 PM
94EG8's Avatar
Seagull Management
Yes, you want something when the key is in on (II) and start. connect them all together and then connect one to the power source.
Old Sep 16, 2012 | 04:31 PM
So basically anything engine sensor related will be an accessory?
Old Sep 16, 2012 | 04:54 PM
https://honda-tech.com/forums/acura-integra-6/obd1-p72-ecu-pinout-2013742/
going off of blueintergaboy's p72 pin out could I run a wire from A15 in the GSR ecu as my accessory power?
Old Sep 16, 2012 | 04:57 PM
94EG8's Avatar
Seagull Management
https://honda-tech.com/forums/showthread.php?t=2013742
No. Also, no 12v switched ignition power wire goes back to the ECU so you're kind of wasting your time looking at ECU pinouts.
Old Sep 16, 2012 | 05:00 PM
What about splicing it into the main relay wire on the drivers harness plug? its also yellow/black.
Old Sep 16, 2012 | 05:11 PM
If I have 2 wires from the harness that used to plug into the 2 injectors (it was a DX) and the 4 wires from the new injectors, the 2 from the harness should already be 12v acc, right?
Old Sep 16, 2012 | 05:13 PM
94EG8's Avatar
Seagull Management
Yes.
Old Sep 16, 2012 | 05:15 PM
ok. I feel dumb. for the help!
Old Sep 16, 2012 | 05:47 PM
crx_si-r's Avatar
make it easy on yourself and use the yellow/black wires coming off your driver side shock tower plug forthe power source.
candyman206
Aug 12, 2024 08:49 PM
tumbaumba
Engine Management and Tuning
Aug 16, 2016 03:34 AM
vegaskurt
May 19, 2005 06:31 PM
1.8turbolsvtec
Nov 10, 2004 02:58 AM
Ryan C
Mar 21, 2004 10:37 PM
