Which Injector for ls/vtec?? venom?
Old Aug 9, 2001 | 05:05 PM
CRX_VTEC's Avatar
Default Which Injector for ls/vtec?? venom?
What injector is everyone runnin for their ls/vtec. I was wondering if the venom are any good or should I just stay with RC270? If so.... how much did everyone pay? I'm still looking on a good price for the RC but seems everyone is pretty much charging the same. (around $320) Anyone know any deals?
Old Aug 9, 2001 | 07:41 PM
EVOCELICA's Avatar
New User
Default Re: Which Injector for ls/vtec?? venom? (CRX_VTEC)
I am using RC270cc and RC says for full drag you should use RC310cc
Old Aug 9, 2001 | 08:20 PM
cjfinkle's Avatar
New User
Default Re: Which Injector for ls/vtec?? venom? (EVOCELICA)
Depending on what year your setup is and what year car it is in, you can go with either 92-96 prelude injectors or 97+ injectors. The 92-92 prelude injectors flow at a rate of 330cc and are low impedence, so if you are running say a PR3 in a CRX, you can use these. If you are OBDII, you can use 97+ Prelude injectors. I believe these flow at a rate of 290cc and are high impedence. What cams and compression are you running? You may not need over 235-240cc.
Old Aug 10, 2001 | 04:19 AM
CRX_VTEC's Avatar
Default Re: Which Injector for ls/vtec?? venom? (cjfinkle)
I know I can use Prelude injectors but I'd rather use aftermarket like RC or Greddy. I'm using type R cams and my compression is around 12:1 I'm pretty sure 270CC will be good. I'll be running around 190-200HP at the wheels if my calulations are correct. I was just wondering if anyone here tried or owned the Venom or Greddy or anyother injectors compaired to the RC or Preludes..??
Old Aug 11, 2001 | 01:24 AM
Big James's Avatar
New User
Please see my comments regarding Venom injectors here. https://honda-tech.com/zerothread?id=58946
b16vtecsol
25
Mar 2, 2004 02:41 PM
youngkow
Apr 2, 2003 11:44 AM
HybridCoupe
Jul 8, 2002 08:28 AM
uneekcrx
Mar 26, 2002 06:11 PM
cjfinkle
Aug 2, 2001 06:39 PM
