The infamous oil leak by the engine code...
Ok, I, as well as many others on the board, have some kind of oil leak around the distrb. , vtec solenoid, etc.. that runs down over the engine/block code. Well, I tried taking eveything apart today , since it was warmer out here. I know , now, that the leak is NOT coming from the distributor. Either the Cam Seals, the vtec solenoid is where i"m thinking. Where else could the leak come from? Head Gasket?
Or is it just one of the two?
you mean that little pool of oil that appeares above the block stamp?
headgasket
its not a serious problem
my b16 did it
headgasket
my b16 did it
I swear... it's always the little stuff that gets ya. They really stick it in and break it off.
I know that alot of people on here have had that problem, I've seen all the threads. I've never replaced cam seals before; I found a couple good step step by step things on the net. I've done the engine swap my self as well as other stuff, just never been 'inside' the engine really. On a scale of 1 to 10 how hard is this gonna be for me?
jdm_xsi206
Jul 17, 2008 07:14 PM
