Idler Pulley Question
Old Jan 23, 2004 | 07:29 AM
-Justin-'s Avatar
Default Idler Pulley Question
Hey guys im about to buy a del sol vtec ac bracket for my b16 swap in my 5th gen hach, so i can retain the stock d-series ac compressor. Will the idler pulley off of the d-series work with the del sol bracket? I know the rubber mount will, but i wasn't sure about that.
TIA
Old Jan 23, 2004 | 12:05 PM
-Justin-'s Avatar
bump, does anyone know?
Old Jan 24, 2004 | 04:27 PM
-Justin-'s Avatar
bump, i need to know guys help me out
Old Jan 24, 2004 | 04:32 PM
Turbogixxer's Avatar
Default Re: (B16EH2)
Use the civic compressor with a del sol DOHC VTEC (p54) a/c mount. The belt has the same amount of ribs IF it is 94+ crank pulley. Older B16s have the one rib style crank pulleys.
Old Jan 24, 2004 | 06:23 PM
-Justin-'s Avatar
i was going to use del sol vtec belts for the ac and alternator, my main question was whether or not i could use the d-series idler pulley with the del sol vtec ac bracket. thanks man.
Old Jan 24, 2004 | 07:35 PM
GhettoR's Avatar
Doing similiar swap and have a p54 on order, will let you know what I see.
Old Jan 24, 2004 | 08:19 PM
JonGP4's Avatar
if ur talking about the tensioner yes they are the same, or can be interchanged
Old Jan 24, 2004 | 08:49 PM
-Justin-'s Avatar
Default Re: (JonGP4)
thanks alot, i have heard different things about whether the tensioner can be used off the d-series, does anyone have personal experience doing this?
Old Jan 25, 2004 | 02:44 PM
-Justin-'s Avatar
bump
Old Jan 26, 2004 | 10:12 PM
-Justin-'s Avatar
up
Old Jan 27, 2004 | 05:34 PM
ef ect's Avatar
ill have to say no on this one. Seams that i had to use the one off a b series due to the d not fitting. But mine is a 97 with a b20 a/c bracket. Should work in your case and it is 1/2 the price on the p54, stamp on b20 bracket was p7j. It has been a year since the swap so i dont know if this is corect, might have used the idler pully off the b20 just cause I had it.
Old Jan 27, 2004 | 05:36 PM
-Justin-'s Avatar
im a bit confused here. did you put a p7j bracket on a b16? sorry for the confusion
Old Feb 1, 2004 | 06:34 PM
-Justin-'s Avatar
bump. will the tensioner work?
Old Feb 2, 2004 | 07:12 AM
-Justin-'s Avatar
Old Feb 7, 2004 | 06:46 AM
GhettoR's Avatar
I ordered a P54 bracket, it came with the idler pulley and mount, for 92 civic si B18C5 motor swap. If in doubt swap it out!
ceasar of mgineering
Jul 19, 2005 10:57 PM
makibaka
13
May 10, 2004 09:13 AM
carsaregood
Feb 9, 2004 11:20 AM
-Justin-
Jan 22, 2004 06:52 AM
